Paper under vices.
Paper under vices.
Home Forums Manual machine tools Paper under vices.
  • #528723
    David Colwill
      @davidcolwill19261
      In a recent post, the idea of placing paper between clamped surfaces was discussed. It is an idea that has many advocates. I am about to remove the vice off the mill for a minor service and was thinking of doing this as I have had it move very slightly in the past. I have some VCI anti rust paper and was wondering if this would be suitable? Has anyone tried this? Am I being stupid?
      Thoughts please.
      David.
      David Colwill
        @davidcolwill19261
        #528726
        John Haine
          @johnhaine32865
          I've never had a vice move under cutting as long as I've tightened the clamp bolts.
          #528729
          David George 1
            @davidgeorge1
            I have seen rust under vices in the past caused by coolant soaking into the paper which was put under a vice. It had been under a long time, maybe a couple of years, on a Bridgeport we had set up just to jump on to mill bits and pieces. When the vice was removed to mill a long job it was a mess stained and surface rust on both bottom if vice an bed of mill. Since then I would never put anything under a vice except wipe with a slightly oily rag and I have never had on move the slightest in 50 years on various mills from 50 tonne mill with 12 inch face mill's to my little bench mill at home. It's more important to use the correct clamps and T bolts etc and checking for swarf between.
            David
            #528731
            Tony Pratt 1
              @tonypratt1
              My industrial experience agrees with David G 1 & I also oil the vice base to stop rusting.
              Tony
              #528734
              derek hall 1
                @derekhall1
                I agree with the comments above, just make sure table is smooth and the bottom of the vice and no swarf can be trapped.
                You can use paper to assist with clamping work between the vice jaws or other clamps but this would only be temporary just for the job in hand.
                Regards to all
                Derek
                #528735
                Clive Foster
                  @clivefoster55965
                  Another vote for oil under the vice. Spread on and wipe off to leave the merest film.
                  Check vice base and table flatness. Generally machines and vices are very good but sometimes you get a pair that are a mutually touch off leaving inadequate clamp down area. If so thin aluminium sheet has sufficient squidge to take up the difference and, unlike paper, won't absorb coolant et al and promote oil / rust stains.
                  Worth checking that the tops of the bolt down lugs are flat and square to the base. If they are significantly out of square and flat the bolts will be pulling at an angle reducing hold down force.
                  Some professionals advocate occasionally stoning the table to remove any burrs that may have arisen. There is a proper stone for this job (expensive!) but a fine oilstone is said to suffice. Sounds overkill to me.
                  #528736
                  Ramon Wilson
                    @ramonwilson3
                    Hi David,
                    I would agree with all – there should be no need to put paper under a vise unless the surfaces are extremely poor – usually unlikely
                    I use a slip of copy paper a lot to aid grip from a clampiing perspective but have never had need to put it under a vise.
                    Ramon (Tug)
                    #528737
                    Ian P
                      @ianp
                      Putting anything compressible under the vice seems illogical to me as the act of tightening the holding down bolts will cause distortion in the vice body.
                      Ian P
                      #528745
                      Anonymous
                        Never had a vice move under cutting forces – work yes, but vice no. I can't see any need to put paper under the vice and introduce an unknown variable that may upset the parallelism of the vice to the table.
                        #528748
                          Posted by Ian P on 20/02/2021 09:02:10:
                          Ian P
                          The logic is that [unless the mating surfaces are flat enough to wring together] … until something distorts there would only be three-point contact between the two metal faces.
                          Therefore, a thin gasket improves the situation, rather than making it worse.
                          By far the biggest risk though, is moisture [as already mentioned by others]
                          … and in reality it should not be necessary
                          Edited By Michael Gilligan on 20/02/2021 09:32:50
                          #528749
                          David Colwill
                            @davidcolwill19261
                            Sold!
                            The minor service is becoming more major and has now moved to regrinding the top and bottom face of the vice which should improve things as the bottom whilst looking okay wasn't very good. Fortunately the vice breaks down to fairly convenient and easily ground pieces, so this shouldn't take too long.
                            I had meant to do this when I got the vice but it was bought to do a job and once that was done the next panic came along and….
                            Thanks for the unanimous verdict!
                            David.
                            #528752
                            Brian Wood
                              @brianwood45127
                              Unless the paper is certified as acid free, the kind that conservators use, I think it is almost certain to promote some kind of interface damage over time to either or both components. And the experience reported on this thread bears that out.
                              I only ever use oily surfaces
                              Edit. I see I am joining the party too late anyway!
                              Edited By Brian Wood on 20/02/2021 09:35:42
                              #528768
                              Phil P
                                @philp
                                Just a little tip about swarf removal……….
                                I use a 12" long strip of aluminium door bottom draught excluder, the type with a brush along one edge, I give the mill table and the underside of the vice a quick brush over with this each time I fit it.
                                You get the whole lot in one go and it is much easier than using a paintbrush etc.
                                Phil
                                #528830
                                larry phelan 1
                                  @larryphelan1
                                  Phil P Ideal for the job, I use the same.
                                  #528836
                                  Anonymous
                                    Posted by Clive Foster on 20/02/2021 08:58:55:
                                    I normally do that once a year during my annual workshop clean up and oil. I use a small, very fine, oilstone that I inherited from a toolmaker.
                                    #528844
                                    John Haine
                                      @johnhaine32865
                                      Posted by Phil P on 20/02/2021 10:24:51:
                                      Phil
                                      I have the same with a rod at right angles to the ali strip, fixed with a screw, that is great for sweeping swarf from under the lathe bed.
                                      #528855
                                      Mike Poole
                                        @mikepoole82104
                                        As many of us will be using vices that have been imported and at the economy end of the market it would be useful to check the base is flat. For those with a decent surface plate a blue check could be interesting and useful. Of course it would be useful to check the table as well.
                                        #528871
                                        David Colwill
                                          @davidcolwill19261
                                          Well the vice is back on the mill!
                                          I stoned the table with a ground flat stone and put some oil on it.
                                          The vice is better now the bottom is flat and I would echo what Mike said.
                                          Overall definitely worth the few hours spent.
                                          David.
                                          #528992
                                          John Reese
                                            @johnreese12848
                                            I don't use paper under the vise. My vise is keyed to the table slot. I loosen the T-bolts and slide the vise to one end of the table when I want to mount a rotary table or something else to the table. I couldn't do that if I used paper under it.
