Yes i agree with things like mobile phones but you only make one mould, Engine blocks are again done as one off's and then cast.
It's the general run of the mill parts that are done in thier millions that work on 2 1/2D.
There are machines out there like the Bridgport clone based machines like the Protrak that you program conversationally at the control, some of these don't even have a powered Z axis and are literally only 2D with Z being worked by hand.
The Hurco which is a full 3D machine can also be programmed at the control and has one of the best conversational programming out there.
If you say that it's only 9% done in 2 1/2D then I and a lot of companies I know have been very busy for the last 20 years.
In fact Solid works, Pro- Engineer and Inventor haven't been about for this long, The only 3D programs that were about this long ago would have been impossible to buy for even a medium sized business.
It's incorrect and throwaway remarks like your original statement that put beginners off from having a go with CNC. They read one mans incorrect interpretation and think "I can't do that" and that's another beginner lost to the hobby.
You are also missing the main point in slagging off Draftsight in that it's a CAD program, CAM is responsible for generation the G code and depending on what CAM you use determines how complex the tool path is.
Not Draftsight but could have been drawn in Draftsight it's that simple.
Just a circle and a cross, copied twice.
Now in CAM if we select merge we get this.
Dependant on which profile we give a positive value to and which way we decide to machine it determines the shape.
Now imagine if we took your mobile phone model and sliced it, then processed the slices.
Or the pattern for a loco cylinder block.
Please do your homework BEFORE making sweeping statements that are incorrect, it only harms the hobby
John S.
[EDIT] To bring things into the cold light of day and following Pauls advise be prepared to pay about £5000 for solid works or inventor, probably £11,000 for Pro- Engineer.
Then you need a capable 3D CAM program to process the 3D drawings and last quote I saw for Mastercam Level 3 was also £11,000.
Edited By John Stevenson on 05/08/2012 10:41:21
