Posted by Paul Lousick on 04/08/2012 09:32:01:
Remeber though that Draftsight is only a 2D CAD program and the DXF files which it could export can only be used in 2D machines such as profile cutting steel plate.
If you want to make files suitable for use in CNC milling machine you will have to have a program that models in 3D such as Solidworks, Pro Engineer or Inventor.
Hope this was useful, Paul
Totaly a wrong statement, 90% of parts produced on CNC machines are done in what is known as 2 1/2D where the X and Y mimic the layout of the flat paper drawing and the depth Z is taken from the drawing and given to the software so it knows how deep to cut.
It has to be like this as you need depth of cut passes as it's very rare unless you have a shallow part that you can cut it in one pass.
Even if you use a full blown expensive 3D CAD package the CAM side of it still needs to know depth of cuts.
In 20 years of working CNC machines I have only needed to resort to 3D on two occasions.
Even this was taken from a flat 2D drawing.
16" diameter, 6" deep and all done from one simple flat drawing with 2 views.
John S.
