pantomime sword
pantomime sword
Home Forums Materials pantomime sword
  • #30180
    duncan webster 1
      @duncanwebster1
      duncan webster 1
        @duncanwebster1
        For my sins I'm part of a group who act out a traditional Souling Play (Cheshire's answer to mummers). I've been dragooned into making a replacement for the Saracen's sword. The current one was made from plywood with the outer ply running longways, but it didn't stand up to being struck sideways. The end bit flew off, fortunately it didn't hit anyone. The handle is also on the verge of coming apart. Question is what do I make the replacement from? Ash? How do I get it to curve? Steaming it and bending in that plane sounds difficult. Anyone got any bright ideas? Obviously it has to be lightweight and non lethal, we have to bring the Saracen back to life after he's been killed by St Georgeimg_20211129_221000.jpg
        #573569
        pgk pgk
          @pgkpgk17461
          Kitchen foil covered plastic? Find an old square tall kitchen bin for stock?
          pgk
          #573570
          Mark Easingwood
            @markeasingwood33578
            Try using "Birch Ply", which is a better quality Plywood than the "Far Eastern Ply" usually sold.
            Or make a former and laminate strips of Ash, as when making an Archery Bow.
            Mark.
            #573578
            Dalboy
              @dalboy
              Look at RC model shops for some decent ply as Mark said Birch ply and probably best for something like 6mm for strength
              #573581
              duncan webster 1
                @duncanwebster1
                I like Mark's glulam suggestion, but birch ply sounds a lot easier. I'll send a picture when it's done. Thanks all who replied
                #573597
                Martin Connelly
                  @martinconnelly55370
                  Could you use ply with a doped outer cover to make a composite material? I think radio control model aircraft use a doped layer over polystyrene for lightweight but stiff wings.
                  Martin C
                  #573647
                  Phil H1
                    @philh196021
                    The boat modelling world also have water based resin to cover a thin and friendly to use glass fibre cloth. I think they use it to cover balsa wood or plywood hulls to give them a little bit of 'ding' resistance plus strength of course..
                    #573648
                    Phil H1
                      @philh196021
                      Can't you also ditch the Saracen bit and replace with a Viking or Anglo Saxon character. Nice straight swords???
                      #573652
                      geoff walker 1
                        @geoffwalker1
                        Duncan,
                        How about a piece of upvc cladding.
                        Eurocell on Winwick road often have damaged fascia offcuts at the rear of shop on the car park.
                        Widest boards are 9mm thick and 250 mm wide.
                        Geoff
                        #573656
                        Mick B1
                          @mickb1
                          Posted by Phil H1 on 30/11/2021 13:07:02:
                          The saexes on the Essex flag are at least as difficult… laugh
                          #573690
                          duncan webster 1
                            @duncanwebster1
                            Ditch the Saracen? wash your mouth out, this is hundreds of years of tradition we're talking about. We've gone all PC and rewritten the 'foul Moroccan dog' line, but that's far enough. St George has a straight sword, this has got to be curved.
                            I'm tending towards birch ply wrapped in glass fibre, I successfully mended the horse's skull using GF after SWMBO managed to break it. Plastic might be a bit heavy.
                            If you want a laugh go to EOS. We usually go round the pubs collecting for Halton Haven Hospice, but not the last 2 years for obvious reasons. This performance was for the videographers college course
                            #573692
                            old mart
                              @oldmart
                              Toledo steel, actors are expendible. laugh
                              #573694
                              noel shelley
                                @noelshelley55608
                                A sign maker locally uses an ali/plastic/ali sandwich about 3 or 4mm thick and quite strong. sand it to remove white coating and your there ! Good Luck, Noel.
                                #573752
                                Neil A
                                  @neila
                                  You could always go out and find a branch of a tree with the right curve, just as they used to do for ships frames many years ago, to get the grain running in the right direction. But don't let anyone see you cutting it off !!
                                  Mick B1
                                    @mickb1
                                    Posted by old mart on 30/11/2021 17:53:56:
                                    Ladder Damascus for a Saracen, surely! surprisewink
                                    #573819
                                    Tim Stevens
                                      @timstevens64731
                                      Fancy – the very idea of changing a Saracen for a Viking for the convenience of the props dept!
                                      Whatever next? Jesus as a white man?
                                      Tim
                                      #573830
                                      Speedy Builder5
                                        @speedybuilder5
                                        How about a nice old "French Curve" Not that I would donate, but I have all my Dad's curves for wing profiles etc in the 1930s. These were cut out of perspex and made in the workshops.
                                        Bob
                                        #574059
                                        Howard Lewis
                                          @howardlewis46836
                                          Now that's a thought,
                                          Cadge an offcut of acrylic, and file / sand to shape and paint before attaching the handle.
                                          Howard.
                                        Home Forums Materials Topics
