Good afternoon bit of a shot in that dark does anybody know the belt pulley diameters for a Pallas v1 milling machine I know there's not many left about thanks
Hi, is it both the motor spindle diameter and the crowned wheel pulley with the clutch in? I can get you a measurement of the crown wheel, but not the motor pulley as unfortunately mine is missing the original motor.
It looks like there may be sufficient info on lathesdotco site for you to work it out for yourself? If one of the speeds is close to motor speed, it should not be too difficult to size the pulleys? I would have thought like not much outside ratios of 2:1?
