Painting PLA
Painting PLA
Home Forums 3D Printers and 3D Printing Painting PLA
  • #558861
    Nick Clarke 3
      @nickclarke3
      Any do's and don'ts when painting PLA 3D prints?
      The things I would to hear people's experiences on are – what types of paint are suitable and what are not (I was thinking of aerosol enamel) and because PLA absorbs water should I aim to totally enclose a print in paint?
      Thanks to everyone who is further down the 3D printing road that I am (ie most people)
      Nick
      Edited By Nick Clarke 3 on 18/08/2021 20:54:47
      Nick Clarke 3
        @nickclarke3
        #558863
          I know much less than you, Nick … but hopefully, one day, the matter will be of interest to me : So I thought it worth a browse.
          https://all3dp.com/2/beginner-s-guide-to-painting-3d-prints-pla-abs/
          Henry Brown
            @henrybrown95529
            I bought some Plasticote acrylic spray cans from Hobbycraft thinking it would be good, unfortunately it wasn't! While it adheres well the primer is difficult to flat and the (silver) top coat was very soft. Just picking the part up left fingerprints even after a good few hours.
            Maybe I did something wrong, I followed the instructions though, but found it to be much harder to spray than normal car (Halfords) paint which I will try next time.
            Haven't needed to spray anything else since as I bought some silver PLA and the Plasticote stuf went in the recycling bin…
            #558912
              Nick, might help to know what the purpose of the painting is eg are you wanting to get a smoother surface for use as a pattern or just decorative in which case is it just going to sit on a shelf or be subjected to weather, oil, etc.
              #558918
              Gordon Tarling
                @gordontarling37126
                Use Halfords plastic primer as first coat, then Halfords primer/filler if required, then almost any compatible paint for colour coat, I'm fond of brush-on acrylics for my railway buildings, but other paints will also work. Top coat of clear lacquer if the item is going to spend any time outside.
                #558920
                Nick Clarke 3
                  @nickclarke3
                  Posted by JasonB on 19/08/2021 10:24:01:
                  A nameplate for an IC engined loco – so will be subjected to weather (but only as long as I will!) but it will be located where solvents, oils etc will not be an issue.
                  It will be the final product not a pattern.
                  Edited By Nick Clarke 3 on 19/08/2021 10:59:02
                  #558923
                  Henry Brown
                    @henrybrown95529
                    Posted by Gordon Tarling on 19/08/2021 10:44:11:
                    Thanks Gordon, that's what I'll do next time…
