painting over rust staining.
Home Forums Workshop Techniques painting over rust staining.
  • #15631
    capnahab
      @capnahab
      capnahab
        @capnahab
        photo 4.jpgThought I would start my renovations with a modest challenge. I have a surface gauge by Brown and Sharpe that was very tatty . I have removed the paint , (nitromors and wire wheel in angle grinder ) – carefully avoiding the inferior surface that contacts the plate. I have predicatbley come across rust staining. (see pictures). This is hardened steel so sanding further (to also get rid of the maching marks ) will be difficult. I will have to repaint , – can anyone recommed primer and paint ?.
        #115837
        Sub Mandrel
          @submandrel
          I would use jenolite to make sure all the rust is neutralised.
          Swarf, Mostly!
            @swarfmostly
            Hi there,
            I agree with Neil about the Jenolite as preparation for painting.
            However, are you sure you've totally got rid of all traces of the Nitromors? I think you rinse with white spirit but I'm not sure about that – I expect the instructions on the tin will tell you.
            Personally, I'd have a go at the corrosion-stained patches with a fibreglass pencil followed by an abrasive filled rubber. Years ago, one brand was called a 'Rust-Rubber' but more recently I've seen them advertised by Garryson (usual disclaimer).
            Best regards,
            Swarf, Mostly!
            #115852
            Ady1
              @ady1
              Malt vinegar?
              10% if you can get it, 5% can be had at tesco for a dollar kinda thing
              Check it each day and scrub with a toothbrush
              Redunk it until you are happy
              DON'T forget about it, the vinegar munches slowly at the metal once the rust has been removed
