Paillons laid on before heating is much more common than stick-feeding among jewellery fabricators. One of the advantages of it for jewellery fabricators is that a very precise amount of solder can be applied to a joint in circumstances where an excess of solder would very probably mean spoiling the contours of a piece whether it was left on or cleaned off.
Experienced fabricators executing multiple small solder joints on a single piece tend to use a slight variation on the paillon laid on before heating: they ball up a paillon on a soldering block by heating it, pick it up on the end of a flux-dipped solder pick or tweezers, and then apply it to exactly where they want it just before the part reaches flow temperature. This method combines the advantages of stick-feeding and paillon laying: it carefully controls the amount of solder on the part and stops the paillon bubbling out of position early in the job.
You can see this technique in action in various parts of this video of the goldsmith Kevork Gurunian at work. Try 24.15 if you want to go straight to an example of it.
Edited By Bill Phinn on 06/03/2021 00:46:18
