P.S.Waverley
P.S.Waverley
Home Forums Model Boats P.S.Waverley
  • #4110
    Martin Field 1
      @martinfield1
      Is there an easily made engine/boiler?
      Martin Field 1
        @martinfield1
        Hi,
        I have a very large model of the P.S.Waverley and am torn between a steam plant and an electric mechanism for the paddle wheels.
        Is there a good steaming boiler that will provide enough steam without requiring a boiler inspection? I have no idea where to get a test done or what's involved, but I can't see a Mamod type boiler giving enough steam to operate the wheels. I don't want to buy a plant.
        Any suggestions gratefully received.
        Martin
        #496184
        Phil H1
          @philh196021
          Martin,
          How long is the model? I have articles for a plant capable of driving a 4 foot long model and the engine for a 6 foot version is still available from Reeves.
          Phil H
          #496194
          Bazyle
            @bazyle
            People tend to over engine model boats, or rather they make the engine then think about a boat to put it in that they can fit in their car. So a typical one is a Stuart D10 or launch engine in a 4ft model when they can easily provide scae power for a 6-7ft one. Part of the trouble is the Stuart Launch engine looks the right proportions in a 4ft launch but then only needs about 20lbs pressure to turn it into a speedboat.
            There is a design for an twin cylinder oscillating engine and launch in the old MAP plans called Miranda. The proportions are not great for a launch (ok lets be honest it looks awful). However some dozen years ago someone on the Paddleducks forum pointed out that you can turn the engine design upside down, keeping the framework the same way up so the crankshaft is over the top. It then closely resembles the sort of oscillator used in paddlwheelers in the mid 19th century. I don't think Waverly actually has that type of engine but still worth consideration.
            Otherwise assuming you don't want a double diagonal have you looked at the "Marcher" engine design which should do for a 4ft boat.
            #496203
            Martin Field 1
              @martinfield1
              I really should have mentioned the size of the boat. It's 5 ft-6in long with paddle wheels about 6" diameter. It's a big devil. I know the Miranda engine, having built one years ago. A launch engine wouldn't be suitable, but it's the boiler I'm most worried about, as a conventional (non pot) boiler needs the inspection for insurance and that's a lot of faff as I've no idea where to get that done.
              It looks more and more like electric power is going in.
              Cheers,
              Martin
              #496213
              Nigel Graham 2
                @nigelgraham2
                I am assuming you live in the UK here.
                You will need the boiler testing for public or club running, yes, but most of us have our models' boilers tested via the model-engineering club scheme.
                You do of course need to be a full member of a club associated ( most, via one of the Federations) with the scheme – but this includes most model-engineering societies and more specifically the Model Power Boat Association..
                You are right: Waverley's engine is not an oscillator, but a triple-expansion diagonal with conventional fixed cylinders and Stephenson's link-motion.
                #496221
                Martin Field 1
                  @martinfield1
                  I do live in the UK, Nigel, but am not a member of a Model Engineering Society. The only one near me was so unfriendly when I visited I came straight home! And it's bad enough having to join the BMFA to insure my model aircraft, without doing it all over again just for a model boat! So, electric it is.
                  Thanks everyone.
                  Martin
                  #496240
                  clogs
                    @clogs
                    Martin try another club first…..they are all not so bad…..
                    I remember being the old fart in the space suit once……
                    all change when they needed a 100hp 4×4 tractor……long storey……still never joined tho….hahaha….
                    independance is a fine thing…..enjoy…..
                    #496241
                      Look for a model boat club as they may be more accommodating and offer have their own pond or lake. If using steam then the gas tank will also need testing and certification
                      #496243
                      Martin Field 1
                        @martinfield1
                        The nearest model boat club is way too far away and there are no other model engineering clubs.
                        I'd forgotten about the gas tank thing as well.
                        No, I don't do asking permission very well, so electric it definitely is, but thanks, gents.
                        Martin
                        #496251
                        Adrian R2
                          @adrianr2
                          How long do you want it to run for? Could you power a steam engine from a refillable Co2 bottle as used on small welders or soda streams? Or use an electric compressor to fill an air tank?
                          (Tin hat on, I have no idea what the consumption of a suitable engine would be and haven't done the sums…)
                          #496271
                          Martin Field 1
                            @martinfield1
                            Adrian, I have already been put off by the rules and regs and likely expense, so will go electric.
                            Cheers,
                            Martin
                            #496296
                            Bazyle
                              @bazyle
                              Check out the Paddleducks forum (speciality paddle boat forum) and Modelboatmayhem forum for advice on what size electric motor to go for. Unless you have an old one you want o make use of there is a new world in electric motors that can double your battery life (or halve its cost).
                              Both the above forums are amateur not-for-profit as far as i'm aware.
                              #496301
                              Circlip
                                @circlip
                                Have you put a dent in the bows for authenticity?
                                Regards Ian.
                                #496303
                                Martin Field 1
                                  @martinfield1
                                  I'll try paddleducks, thanks. ModelBoatmayhem I was chucked off years ago for criticising somebody's prices. I think he's dead now but they still won't have me!
                                  I would rather use an older motor in keeping with the model. I have several Taycols and clever electrical bits to allow the use of a modern ESC with the field wound Taycol motor.
                                  Martin
                                  #496304
                                  Martin Field 1
                                    @martinfield1
                                    Is there one, Ian? What did it hit?
                                    I know very little about it, but it was a birthday p[resent and has to be finished.
                                    Martin
                                    #496316
                                    V8Eng
                                      @v8eng
                                      Posted by Martin Field on 17/09/2020 12:23:21:
                                      Martin
                                      I think it hit the pier on Arran earlier this month.
                                      Found the story now, link here:-
                                      Waverley
                                      #496317
                                      Bazyle
                                        @bazyle
                                        Good to hear someone is still using Tycols. I have a Supermarine which in a way would be suitable with the shaft being available both ends. A bit of chain drive would be sort of in keeping too.
                                        Edited By Bazyle on 17/09/2020 13:55:51
                                        #496338
                                        Circlip
                                          @circlip
                                          "Is there one, Ian? What did it hit?"
                                          Yep, straight out of boiler rebuild, first passenger trip and BOING! As the late S/J would have said "C-B". As it's of a "Size", separate drives to paddles using a couple of reversible crash gearboxes coupled to Taycol would work. Simply made to a "Beek" design.
                                          Regards Ian.
                                          #496345
                                          Martin Field 1
                                            @martinfield1
                                            Taycols were fine once, they still are. A chap from another forum designed and built me some electric boxes of tricks that enable me to use current brushed ESCs with a Taycol motor, so I'll use one of those for Waverley.
                                            As someone pointed out independent paddle wheels only causes roll, so a BIG rudder may be in order.
                                            Bazyle, chain drive could work if I can get a big enough sprocket for the shaft to get the reduction. And, of course, I have no idea what speed the wheels should turn.
                                            Martin
                                            #496348
                                              My dad would recommend one of the hefty double-ended cab fan motors used by JCB.
                                              He has a couple that found their way out of the reject bin for being too noisy but they are not very noisy at all, JCB must be very fussy.
                                              Martin Field 1
                                                @martinfield1
                                                They sound great, Neil, but JCB know how to charge! Like 30 quid for one mudguard bolt. Never paid their own bills very quickly though!
                                                M
                                              Home Forums Model Boats Topics
