Posted by Chris Baetens on 20/04/2017 08:22:22:
Some more pictures while cannibalizing it even more.
Two brushes are angled at 180° and a third one is angled at (about) 60°.
So that explains it about the two different speeds I suppose.
I did mention this previously about the motor having two speeds…….obviously missed by many I guess….
If you connected your supply directly to the two wires rather than one wire and the casing, it will make the motor run hot!
"Have you considered that the motor may be a two speed job?
The negative connected to the body of the motor and the positive connected to one of the two wires for the two speeds?
Ordinarily, the brushes would be opposite each other with half of the armature connected across the supply, with a third brush contacting a reduced number of coils, would give a higher speed but an increase in current….."
Edited By John Rudd on 20/04/2017 09:23:01
