Posted by Ian Phillips on 18/04/2017 14:07:17:
Whatever the vise is made from I am visualising your whole machine being held to the bar you are cutting, which in turn is held in the bench vise
Ian P
I can imagine what you must thing about this project Ian, and maybe about me to. And I think you're not the only one.
May I explain a bit about myself please : I'm not a spring-chicken anymore, I am a mechanical engineer, know my way in 3D-drawing(Autodesk-Inventor), Know my way rather good in 3D-printing. I even designed my own printer, designed and printed lots of things with it. The largest thing I printed so far is a (rather large) telescope.(scroll to bottom of page).
Most importantl, I want to do things (most of the time) a bit different.
A long time ago I started my carrier with 2 drill presses, a lathe, and a large milling machine. Until a few years back a made Stirling engines, had lots of fun making these. And then, 3 years ago I bought a 3D-printer. And that's when it all changed.
Every time again, when I start a new project, I step into my workshop, the first thing I have te decide : How will I proceed with this new project : will I use my mechanical machines or shall I print it, or just maybe I will use both techniques combined…? Very often I'll go with the printers, because there's almost no limit what I can do with it. I mean,comparing the possibilities using lathe/milling to printing, my choise is very quick made. I know, I'm not in the right forum to say things like this, but please let me explain.
When I draw a very complex object in Inventor, there's absolutely no way I can make that object with a lathe/milling. Even with CNC machines, believe me. I can show objects I've printed impossible to make the classical way.
Will this powered hacksaw work, well I do not know. I think it will. While drawing it I will be forced to think ahead and balance what will be printed and what will be made by other means. Goal is of coarse to print as many objects as possible.
This an example what I can do with a 3D-printer. There are 8 holes in this part that are angled. When this XY-carriage is completely assembled, it will contain 14 ball-bearings, that are perfectly aligned. Through this block runs also a square hole to allow electronics to be mounted and the wiring for it. Most of the holes will be reamed.
Printtime for this object : about 5 hours. This part is printed to make me another 3D-printer.
