P M Research No 4
P M Research No 4
Home Forums Stationary engines P M Research No 4
  • #3551
    Ian McVickers
      @ianmcvickers56553
      Ian McVickers
        @ianmcvickers56553
        Hi all,
        Ive finally managed to get my PM Research No 4 nearing completion and running on air.
        Video here https://youtu.be/e2f2Lar4r8M
        I still have drip feed oilers to make for the stand,probably similar to the other 2 and was also thinking about a lid for them.
        This was definitely a challenge to machine especially the stand. I will probably put the flywheel back on the lathe and redo it as I`m not happy with the finish and see about improving it. There is also a bit of wobble on the fly wheel due to the crank not being perfect but I will blame it on it being in 5 pieces and a pain to get true.
        #651939
          Looks to be running well. Regarding the crankshaft it is usual to make them from 4 pieces with the shaft full length and then cut out the middle of that once it has been assembled which helps keep the shaft straight.
          #652104
          Ian McVickers
            @ianmcvickers56553
            Thanks Jason.
            I assembled it as per the drawings and it was straight after assembly but isnt now. Its not out by much so maybe when I redo the flywheel I might attempt to straighten it out.
            Just noticed the spelling mistake in the thread title, can this be fixed?
            #653087
            Blue Heeler
              @blueheeler
              Very nice build of a No4.
            Home Forums Stationary engines Topics
