hello thanks for your interest, , john and bob. firstly my initial concept was to use this system so as to not be purchasing oxygen refills, all i wanted was to do some welding ,brazing without being tied to consumables. so i looked at how, acetylene is produced, and then oxygen, i kind of bumped into it while researching, the design is not my own in fact it is used in a few areas, one being oxygen concentrators used for the medical industry, for people who need purer air , oxygen than the norm, there are also uses by the military, and it is used to produce nitrogen and oxygen, in the nitrogen process oxygen is the waste product with argon and other trace gases, simple process . compressed air is pumped through a zeolite, molecular sieve, to about 120 p.s.i. oxygen or nitrogen depending on your sieve is separated from the air mix, , you can harness either or both,. there is a brilliant design in (Instructables, by imsmoother) full assembly and materials it uses 40 kilograms of molecular sieve, 20 in each reservoir. the creator of this particular model uses it to harness nitrogen, he then goes on and liquidises the nitrogen, very clever, does it on his driveway, however inititialy i want one . i am interested in modifying this design, using smaller materials, it would make more cost effective. so any thoughts would be appreciated, i have just located a supplier for the molecular sieve in the uk, took me ages to find. heres a picture
