Oversize Cylinder
Oversize Cylinder
Home Forums Beginners questions Oversize Cylinder
  • #50632
    Richard Stacey
      @richardstacey70920
      A newcomer to model engineering, I am in the process of building the Stuart S50 Steam Engine and due to a bad error in measurement I have bored the cylinder
      31 thou oversize.  Will it be OK to machine the piston to fit or do I have to buy a new cylinder casting and start again?
      Many thanks
      Richard
      Richard Stacey
        @richardstacey70920
        #50633
          Can’t see why you should not be able to use an oversize piston.
          Just make sure the larger bore has not affected the cast in steam ways and remember to machine the spigot on the cylinder covers to fit the bore as well. You may want to drill the cylinder cover bolts and a slightly larger PCD if they come close to the bore.
          Jason
          #50635
          Richard Stacey
            @richardstacey70920
            Many thanks for that Jason, as far as I can see there is no problem with the steam ways. Having managed to make the cutter bit for the boring bar and machine the bore parallel, I would have been disappointed if I had to start again. Thanks also for the tips about the cylinder covers and PCD for the bolts – I hadn’t thought of that!!
            Richard
            #50636
            chris stephens
              @chrisstephens63393
              Hi Richard,
              Don’t look on your “mistake” as a negative, just think of it as a larger, more powerful version of the engine.
              chriStephens
              #50644
              Circlip
                @circlip
                You have highlighted one of the traps that most who “Mod” a design fall into Richard. Yours was one of neccessity due to an error of machining, but the same thing applies to two other forum golden oldies, Merticating designs from imperial and the “Why are the drawings not corrected” whingers.
                  Pity they don’t engage brain before trying to melt the keyboard.
                  You may be able to re-centralise the PCD between the edge of the bore and the flange O/D.
                  Regards  Ian.
                #50648
                Richard Stacey
                  @richardstacey70920
                  Thanks Chris,
                  I’m all in favour of positive thinking – all encouraging comments gratefully received.
                  Richard
                  #50649
                  Richard Stacey
                    @richardstacey70920
                    Hi Ian,
                    I have checked the cylinder flange and there is no problem in centralising the retaining bolts with just a small increase in the PCD.
                    Richard
                    #50656
                    mgj
                      @mgj
                      How did you make the error in the first place – just as a matter of interest.
                      As I recall the first hole I ever bored was a trifle ! oversize too
                      #50657
                      chris stephens
                        @chrisstephens63393
                        If you think about it, a hole can either be right or oversize, if it were “under-size” it would simply be ‘work in progress’ or if you like, unfinished. There’s one for you lot to ponder on.
                        chriStephens
