Overload trip
Overload trip
Home Forums Electronics in the Workshop Overload trip
Viewing 25 posts - 1 through 25 (of 34 total)
  • #395324
    Stephen Spice
      @stephenspice48575
      I have recently completed ( all but the extended dial ) John Wildings. A Small Weight Driven Tower Clock.
      I opted for the automatic electric winding and was very pleased with the result
      With a Mercury tilt switch the clock wound its self three times in 24 hours and only had to wind for less than 10 seconds at a time.
      This worked very well for some months but unfortunately I had a chain climb on its self jamming the motor which was still trying to work and causing it to overheat.
      This did not blow a fuse of course because it didn't short to earth. And if I hadn't been there I assume it might have resulted in a fire.
      Unfortunately I am not able to replicate the problem and so cant make sure it couldn't happen again. Everything being absolutely free I cant see how it could possibly happen.
      But as it did I just cant use it short of adding some sort of overload trip.
      I know this can easily be done with much larger motors. But this being just an 8 watt motor with a 20 .1 gearbox. presents a problem.
      This very nice motor / gearbox cost me £ 430. And enquiries with the manufacturers I could have it rewound with an overload in the wiring for another £ 600. I haven't won the Lottery recently so this is out of the question. And if there was another problem I wonder if this would mean a rewind every time.
      If anyone has any ideas about this it would be much appreciated.
      If I can't solve this problem I see no alterative but to alter this clock to manual winding which would a pity after putting so much work into the electric winding alone. And then I would have another problem with the required long weight drop.
      Thanks. Stephen Spice.
      Stephen Spice
        @stephenspice48575
        8 watt 250 volt AC motor / gearbox.
        #395326
        Brian Sweeting 2
          @briansweeting2
          May I ask what the voltage of the motor is and is it ac or dc?
          #395327
            Brian,
            The thread subtitle declares:
            "8 watt 250 volt AC motor / gearbox."
            Brian Sweeting 2
              @briansweeting2
              Posted by Michael Gilligan on 08/02/2019 19:34:19:
              Brian,
              Thank you MichaelG, I hadn't read or adsorbed that bit of the title, I'll sit in the corner quietly for a bit.
              #395329
              Jeff Dayman
                @jeffdayman43397
                Hi Stephen, I think what you may need is a fuse or circuit breaker inline with your motor wiring that senses over current condition during motor stall, and shuts off. An automotive or marine type inline ATC fuse is likely the cheapest option. Probably can get them in UK at car parts stores, lots of available current ratings. Second link – You can buy circuit breakers that have a manual push button reset, in many current ratings. You choose one that breaks at say 500 mA or a bit more above the normal operating current of your motor. Electronics supply firms will be able to get these. Hope these ideas help.
                https://www.e-t-a.com/products/circuit_protection_devices/thermal_overcurrent_circuit_breakers/p/105/
                #395330
                  Stephen,
                  Just thinking aloud …
                  Might a reasonable alternative be to detect a 'stoppage' rather than an 'overload' ?
                  … It may be simpler to implement.
                  Brian Sweeting 2
                    @briansweeting2
                    Right, 8amps and 230vac would be a suitable size for a regular motor overload device however a temperature sensing motor protection thermistor might be a better solution.
                    This link is to an American source but gives a good insight into the device.
                      Posted by Brian Sweeting on 08/02/2019 19:36:56:
                      It happens a lot round here, Brian
                      Do keep thinking whilst you are sitting quietly.
                      Ian Parkin
                        @ianparkin39383
                        Remember that the current draw for this motor is only 33mA so even a fuse will struggle to protect that
                        I’d agree that some way of detecting a stoppage would be best
                        #395349
                        David George 1
                          @davidgeorge1
                          Hi you could put a spring loaded disc on the motor shaft which disconnects power when overloaded.
                          David
                          #395352
                            I'm guessing from the high price that the motor and gearbox are proper clock items and it might be undesirable to mess with them by trying to place sensors etc. Possibly the protective measures would spoil the look of a fine clock.
                            Another way of approaching the problem might be to connect the clock to power via a cheap mains timer that strictly rations how long the clock is given power. Given that the clock only winds for 10 seconds 3 times per day, you could set the mains timer so that power was only applied to the winder, say, 4 times a day in 1 minute bursts. Then, even if the motor jammed, it wouldn't matter much because the power would be automatically disconnected after 1 minute allowing it to cool for 6 hours. ( I suspect an 8W motor could be stalled for 60 seconds without overheating.) The timer is an easy no mods fix plugged unobtrusively into the mains socket.
                            Looking at the various models sold by Screwfix it looks as if the mechanical models switch on for a minimum period of about 5 minutes (which might still be OK) but some at least of the electronic ones can do 1 minute.
                            Martin Cargill
                              @martincargill50290
                              Have a look on Ebay there are loads of thermostatic switches available in a range of temperature settings. One of these fastened to the motor and wired into its power supply will be able to cut the power if the motor overheats. Wired in this manner it will reset and try again once the motor cools down but it will cycle like this without letting the motor reach any serious temperatures.
                              Martin
                              #395359
                              Emgee
                                @emgee
                                Hi Stephen, depending of course on the power required and rpm for the drive to the winding gear have you considered using a small DC motor with gearbox attached as the power source, you would of course have to provide a control for the motor, these are widely available with speed control and low cost, the existing 240/250v ac mains supply could be used to power a suitable ac transformer and rectifier circuit for the low DC voltage required for the new motor.
                                A picture or 2 would help with judging physical size limitations.
                                Emgee
                                #395360
                                Stuart Smith 5
                                  @stuartsmith5
                                  #395365
                                  John Haine
                                    @johnhaine32865
                                    It would help if we knew more about the motor/gearbox. 8W is a very low power motor – is this one of those little synchronous motor/gearbox combinations? If it overheats when jammed that suggests that the stall current is quite a lot larger than the running current, though probably not nearly enough to blow a fuse. A possible solution would be a current sensor and a bit of circuitry to switch off the power and probably sound an alarm if the current rises above a threshold. Possibly a clip-on current sensor could be persuaded to work, or a proper current transformer. A quick search on RS indicates that most off the shelf protection relays can't really go down to the current you have.
                                    #395391
                                    not done it yet
                                      @notdoneityet
                                      Check its stall current and fit a slow-blow fuse? Should start even with a mometary power surge, but blow after a few seconds of stall.
                                      Doesn’t make the problem go away, mind, but no point in having even a one amp fuse for a motor that size. It will draw rather more than 8W when stalled. A timing circuit to ensure continued operation would be good, too. It needs protection against burning out the motor winding
                                      #395405
                                      Speedy Builder5
                                        @speedybuilder5
                                        Over temp fuse attached to the frame of the motor ?? Most bread makers, microwaves and toasters seem to have them somewhere inside – ebay.
                                        #395414
                                        Andy Carruthers
                                          @andycarruthers33275
                                          Just before go and sit in the corner… would a shear-pin work?
                                          #395416
                                            Posted by not done it yet on 09/02/2019 05:08:57:
                                            Check its stall current and fit a slow-blow fuse? …
                                            Probably not necessary to be that clever. An 240V 8W motor will draw 33mA at full load. We don't know how hard the motor works when winding the clock, but it might be a significant proportion of 8W if it lifts a heavy clock weight in 10 seconds. Even so, the fuse only has to cope with a short burst of current. 32mA is a standard size instrument fuse and I'd use the ordinary fast blow version.  It shouldn't blow when presented with 33mA for only 10 seconds and it's more likely to blow quickly if the motor is genuinely in trouble.
                                            A suitable holder and box would also be necessary – this type of fuse won't clip into a mains plug!
                                            When looking at the fuses listed by RS Components I noticed they're using a new-to-me suffix to encode the fuse type. In case the scheme is unfamiliar to anyone else:
                                            FF – very fast blow
                                            F – fast blow (the common type)
                                            M – medium blow
                                            T – slow blow
                                            TT – very slow blow
                                            Edited By SillyOldDuffer on 09/02/2019 10:37:30
                                            #395417
                                            Roger Hart
                                              @rogerhart88496
                                              You might like to try the small synchronous motors used in central heating diverter valves. They are designed to operate stalled (and get a bit hot!) without burning out. In the stalled mode there is usually a resistor and a diode in series with the motor. They are internally geared down a lot so operate at a civilised speed.
                                              These motors are pretty cheap in the usual place and come with a small pinion and have a useful torque.
                                              #395432
                                              Tim Stevens
                                                @timstevens64731
                                                If you could mount the motor so that it is able to pivot – like the dynamos and alternators on cars – you could use a spring to hold the motor on one side of the slack, with a switch to turn off the input if the motor moved to the stalled side. You would need to adjust the spring tension so that in the stall condition, as the motor tries to haul itself towards the driven side, the stalled movement always operates the switch. Use a switch that turns off and stays off (not a microswitch) to avoid any tendency for the motor and spring to bounce to and fro when stalled.
                                                Not the best explanation I have offered, but I hope you see what I mean.
                                                Regards, Tim
                                                #395448
                                                  In the absence of a picture of Stephen's mechanism … this might be a useful reference: **LINK**
                                                  https://www.bonhams.com/auctions/18836/lot/286/
                                                  [ ignore the green movement, that's not a Wilding clock ]
                                                  _____________________________________________
                                                  I would like, if I may, to expand a little on yesterday's suggestion:
                                                  My thinking is that a 'missing pulse detector' would be the optimum solution.
                                                  The logic would be very simple:
                                                  • IF the Mercury Switch is closed AND the pulse train is active THEN all is well, so allow it to continue.
                                                  • IF the Mercury Switch is closed AND the pulse train is NOT active THEN there is a jam, so isolate the motor.
                                                  The pulse generator could sense motor rotation, chain movement, or wheel rotation [etc.] according to taste.
                                                  Edited By Michael Gilligan on 09/02/2019 13:20:48
                                                  #395469
                                                  Brian Oldford
                                                    @brianoldford70365
                                                    Posted by SillyOldDuffer on 09/02/2019 10:34:57:
                                                    FF – very fast blow
                                                    M – medium blow
                                                    T – slow blow
                                                    TT – very slow blow
                                                    You overlooking the even faster fuses. They have three legs. We usually call them transistors. cheeky
                                                    #395487
                                                      Posted by Brian Oldford on 09/02/2019 17:36:33:
                                                      FF – very fast blow
                                                      M – medium blow
                                                      T – slow blow
                                                      TT – very slow blow
                                                      Isn't that kind of comment called a 'low blow' . Groan.
                                                      I should be on the stage. There's one leaving right now…
