Hi everyone,
Right then, about this grinder.
According to the instruction manual (which covers four grinders from 150W (mine) up to 550W) it is a Clarke CBG-5RSB Heavy Duty Bench Grinder. There is an exploded diagram which does indeed show ventilation holes at the bottom of the end caps, a fan, a centrifugal starting switch and a motor starting capacitor. My grinder does have the ventilation holes and a 3microfarad capacitor which as far as I can tell is directly connected to a winding. It does NOT have either a fan or a centrifugal starting switch.
The inside of the machine is very clean, surprisingly so, but then, there is nothing to suck air and dirt into it. And the run down time after switch off is quite long. Nor does there seem to be any undue resistance when rotating by hand, so I don’t see any problem there.
I therefore conclude that despite the “Heavy Duty” tag, it is nothing of the sort, and is meant for light domestic occasional duty use, and indeed, using it in this manner it has run satisfactorily for these last 20 years. It is only when I get into long periods of continuous use does it seemingly get too hot.
Internally, the field coils are mounted on a frame which itself is supported by the outer casing by a small number of pillars. It therefore makes me wonder just what the internal temperature is when the outer casing gets as hot as it does. Another reason for treating it carefully.
Meyrick, you said that your grinder does not run hot. I’d be interested to know, for comparison, what the spec is for your machine, eg power rating, fan etc.
Now about the present project.
I haven’t annealed the old file because sometime ago, I tried doing just that by putting some old files into the late evening fire, and whilst they were definitely soft, the outer part simply flaked off. In any case, I created a parting off tool by grinding down an old 4″ file to produce a blade about 1.8mm thick by 10-12mm long and since this worked extremely well, I thought I would use the same technique.
The idea of using an angle grinder for the initial shaping simply did occur, which is rather silly since I have indeed used my angle grinder to cut up an old 10 or 12″ file for use as lathe tools. Perhaps that says more about my inability to perform lateral thinking than anything else!
And finally to Circlip. Eh lad, tha hasn’t seen mah workshop. It’d take quite a number of these machines to overcome the heat loss through the roll up door, the single skin walls, the single skin flat roof, the concrete floor, etc. To be honest, I’ve given up trying to keep the place warm – it’s easier to ensure that the expensive machinery doesn’t rust by using individual machine heaters or liberal doses of WD40, and for me to dress accordingly.
So there we are, I don’t think I’ve a problem – just an underpowered low spec device aimed at the casual homebased user.
Peter G. Shaw
Edited By Peter G. Shaw on 05/11/2009 15:32:38
