Oval S/S tube required
Home Forums Materials Oval S/S tube required
  • #29742
    Gordon Tarling
      @gordontarling37126
      Gordon Tarling
        @gordontarling37126
        Does anyone know where I might be able to buy some oval stainless steel tubing? It needs to be approx 12.5mm x 4.5mm and wall thickness is something I'll have to accept, but around 0.5mm would be ideal. I can find streamline tube, but that's not really the correct section, though I may just have to accept that if nothing else turns up. I'll probably require about 2m in total.
        #314297
          I made oval aluminium tube for a mast by squeezing round tube in the vice and turning the handle to exactly the same point.
          If you need greater accuracy, you could use stops in the jaws. Or with stainless, stick a bar down the middle.
          Edited By Neil Wyatt on 28/08/2017 16:19:40
          #314300
            Like Neil I have pressed steel tube in a vice but if you need along length then rolling may be a better option.
            The two sides of this part are about 10" long and of similar overall section to what you are looking for, about 1.0mm wall.
            #314395
            Gordon Tarling
              @gordontarling37126
              Thanks chaps – looks like flattening some is my best bet, so I'll try to find some suitable round tube and give it a try.
              Jason – did you roll those 10" lengths in your photos? If so, how did you do that?
              #314405
                No all just done in the bench vice with a bit of elbow power and then tidied up on the linisher, I thought I had a better photo of the tube somewhere will have a look, there is a thread on here about it.
                #314412
                  There is a photo of the tube section I ended up with in this thread plus other suggestions on how to for it
                  #314418
                  Ian S C
                    @iansc
                    How about a pair of steel rollers in a frame, the rollers made with a suitable profile, and placed at a suitable distance apart, should be ok for .5 mm or less. you would probably need to flatten the tube at the end before you start to feed it through the rollers.
                    Ian S C
                    #314422
                    Martin Connelly
                      @martinconnelly55370
                      This is a piece of 3/8" od 22 swg tube in 316L stainless. Current cost about £4.50 per metre from SPS. Just squeezed in a 6" vice. The width is 12.8mm and the thickness is 4.9mm.
                      Squashed 3/8 tube
                      If I was doing it for anything other than a test I would have filled the tube with dry sand or something similar to stop the flat face from collapsing. It is a bit figure of 8 in cross section.
                      Martin C
                      #314449
                      Gordon Tarling
                        @gordontarling37126
                        Thanks for the suggestions folks – very useful!
                        Jason – your efforts are up to your usual standard, but I don't really want to get into sanding to eliminate surface irregularities if I can possibly help it.
                        Ian SC – I'd considered rolling it somehow, but I fear that I'd end up with something other than straight, though it could be worth a try.
                        Martin – That looks almost ideal to me. Do you feel that dry sand would allow the sides to stay flat? I suppose I might be able to get away with inserting a flat strip of brass or steel during the forming. I'd have to hope that I'll be able to remove it though! Can't find 3/8" tube of any kind on the SPS website – do I have the right SPS?
                        I'll get some tube ordered and start doing some experimenting.
                        #314540
                        Martin Connelly
                          SPS (specialist pipe services) Hull. They may not list everything since they may buy it to pass it on. What lengths do you require? If it is one length totaling 2m they may want to send you a 6m length. On the other hand getting offcuts as scrap from our work bins may result in the required quantity at a minor cost.
                          Martin C
                          #314567
                          Gordon Tarling
                            @gordontarling37126
                            Martin – Thanks, I'll give them a call to see what they can supply. I need 6 lengths of around 300mm, say 2m in total. If I have to buy 6m, then I will, just as long as they don't send it in one length!
                            #314652
                            Martin Connelly
                              Gordon, you have a message in your inbox.
                              Martin C
                              #314719
                              Gordon Tarling
                                @gordontarling37126
                                PM replied to, thanks!
                                #314974
                                Gordon Tarling
                                  @gordontarling37126
                                  I'd just like to say a very public thank you to Martin Connelly for his help with this. I have just received a package from him which contains all the S/S tubing that I'm likely to need for this project, along with the test piece that he made. His generosity is very much appreciated. This forum is great, long may it continue!
                                  #315002
                                  Circlip
                                    @circlip
                                    Hopefully it's seamless?
                                    Regards Ian
                                    #315049
                                    Martin Connelly
                                      Yes, seamless.
                                      Martin C
                                    Home Forums Materials Topics
