OT Analogue tachographs (Kienzle?)
Home Forums Related Hobbies including Vehicle Restoration OT Analogue tachographs (Kienzle?)
  • #222085
    frank brown
      @frankbrown22225
      I was helping my mate replace the tacho cable on a vintage coach. After we did this we took it out for a spin and the odometer was clocking up the distance but the speed indicator was not working. We opened it up and there was a white slider which we moved to the other position. After this the speedo worked. I can't think why the speedo would have an option to turn it off. Any thoughts. ?
      Frank
      frank brown
        @frankbrown22225
        #222086
        John Haine
          @johnhaine32865
          National market option for countries that don't require speed recording?
          #222087
          Speedy Builder5
            @speedybuilder5
            MOT – what would the tester say if the mechanical speedo read 30 Mph and the Tacho 40 Mph ??
            #222091
            Chris Evans 6
              @chrisevans6
              Google Mr Tachograph and ask him, this guy knows all about them and worked for Kienzle.
              #222107
              Watford
                @watford
                Posted by Speedy Builder5 on 22/01/2016 09:01:52:
                He would probably say that you have a seriously bad case of clutch slip.
                #222165
                frank brown
                  @frankbrown22225
                  Oh no, the disc speed recording worked, we could see the pointers(pens? pencils?) that record the speed move out from the centre as we went really fast (25 MPH). Just had a thought, I wonder if its an interlock, so when there is no disc fitted the "speedo" bit does not work. Wonder why you can manually over ride it.
                  Frank
