Optical Alignment Device
Home Forums Related Hobbies including Vehicle Restoration Optical Alignment Device
  • #658919
      Fans of Dan Gelbart might recognise the principle of this one:
      https://www.huberlab.org/resources/optical-alignment-device/
        old mart
          @oldmart
          Clever design, I did not understand how the laser image presented a circular image and whether that image diameter reduced to a point when the axes were exactly at right angles in all planes. Particularly how the persistance of the projected beam worked. Normally such a beam would always only show as a spot, not a circle.
          #659099
            Ian P
              @ianp
              Unless I have misunderstood the details in the abstract and the fuller description in the second link, I dont think this device will be any use for centering a workpiece.
              Its purpose seems to be to (only) ensure that the window is perfectly perpendicular to the microscope optical axis.
              Ian P
              #659131
                You have not misunderstood, Ian
                … this the optical equivalent of ‘tramming’
                Edited By Michael Gilligan on 05/09/2023 04:16:27
                #659200
                Ian P
                  @ianp
                  Posted by Michael Gilligan on 05/09/2023 04:07:44:
                  I totally agree Michael.
                  However the device I saw in a Dan Gelbart video was for centering work for drilling/milling not tramming.
                  I will have to read the paper again but I did not get the impression that the accuracy of the optical device would be as good as using conventional (Spindle mounted DTI swinging over the table) but for its medical purpose it makse sense.
                  Ian P
                  #659201
                  Ian P
                    @ianp
                    Ian P
                    #659206
                      Posted by Ian P on 05/09/2023 13:40:28:
                      Ian P
                      Sorry if the comment in my opening post was misleading, Ian
                      What I meant was that it was an evolution from Dan Gelbart’s device.
