Open Crank IC Plans
Open Crank IC Plans
Home Forums Beginners questions Open Crank IC Plans
  • #402266
    Philip Burley
      @philipburley44197
      hello , has anyone come across plans for an open crank engine made from bar stock ?
      Philip Burley
        @philipburley44197
        #402267
        John Rudd
          @johnrudd16576
          Steam or ic?
          There is the Webster OC engine that is ic….
          #402271
            The Webster and kerzel open crank hit and miss engines can be found on the web if you want something small.
            Model Engine Builder will sell the two back issues that have very good drawings for the Zero-six engine in digital format for a modest cost. I built it with some modifications so it did not look so much like a barstock engine but mechanically all the same.
            Jerry Howell's "farmboy" is also a nice looking opencrank from barstock and ideal for those that like making aluminium swarf
            Edited By JasonB on 26/03/2019 12:36:46
            #402273
            Bazyle
              @bazyle
              It started here Dad's horizontal
              went on here still horizontal
              There's no stopping him now vertical but this thread starts a bit funny, page two has a picture.
              Stewart has done more and more complex
              BTW it would help others in future searches if you made your title more explanatory and the text a bit more detailed.
              #402280
              Philip Burley
                @philipburley44197
                sorry , I should have indicated that I am after an IC engine , made several steamers , and just fancied a change , but the casting sets are so expensive
                #402281
                  One more for the list but it's quite big. J & E Junior
                  #402282
                  Philip Burley
                    @philipburley44197
                    the J&E looks interesting , if it was reduced a bit
                    #402283
                      Yes I should think half or two thirds that size would work out OK. If you prefer metric then working to a ratio of 1/16" = 1mm will give mostly whole numbers, 192mm dia flywheels and 32mm bore.
                      #402354
                      John Olsen
                        @johnolsen79199
                        The Rina engine was described in Model Engineer a few years back. were a few problem areas in the drawings but I can help with corrections. I haven't actually built the engine.
