Only for Myford lathes
Home Forums Work In Progress and completed items Only for Myford lathes
Viewing 25 posts - 1 through 25 (of 99 total)
  • #446040
    Steviegtr
      @steviegtr
      So I thought I would start a thread (I hope it is in the right section) sorry Neil if it's not. Anyway a very short history. I many years ago bought a Boxford lathe from a college clear out. Whitwood college near Castleford for a measly sum of £50 After a friend tightened up a few bits on it the thing worked ok. I made many bits on it. Then got too consumed with my Electrical contracting business that I had no spare time so I sold it for the same amount to a friend, who still has it. That was over 20 yrs ago. So move on to retirement. I have just recently purchased a Myford Super 7B 1977 vintage lathe. I was going down the Chinese route at some £550. But ended up buying this of which I do not regret, but up around the £3000 point now with purchase & all the bits i keep buying. Note to oneself (stop going on E-bay). This model has a clutch, powered cross feed, Quick change gearbox, broad bed cross slide & all the other features of that model era. I travelled to Kent from Leeds to pick it up. God the traffic, i'm glad I am retired as used to travel to London & the south quite a lot, I digress. So we lifted it onto the bench & I thought yes what a lovely piece of kit. Trouble is I can never leave anything alone. So I have fitted a Dro Tacho. New belts meaning the headstock had to be stripped. A inverter & when it eventually comes a 3ph motor. I have ordered a wedge type 250-111 quick change tool post from the good old US of A. I have built a control panel for the inverter & had a tray made for it to sit on a work bench. Eventually I will be using it & have lots of jobs waiting to be done. So anyone reading this with any Myford lathe ,,, what have you done to yours since you have had it.
      Steviegtr
        @steviegtr
        Mods & tips for the Myford lathes.
        #446047
        John Baguley
          @johnbaguley78655
          I bought my ML7 brand new in 1973 from the old Reeves (£150!) when they were in Birmingham and it is still my prefered lathe. It's been in constant use since then. Apart from fitting a 3ph motor with inverter some years ago I haven't had to do much to it at all. I soon replaced the original tool post with a quick change job which made tool changing much easier.
          I did recently pick up a virtually brand new spindle and a set of NOS white metal bearing shells which I fitted last year but it didn't really need it. I had scraped the original shells a couple of years ago but the wear was very slight.
          One improvement I made last year was to replace the original Vee belts with the cogged variety which are more flexible and it now runs much smoother than before.
          Steviegtr
            @steviegtr
            Wow I bet there are not that many people who have stayed faithful to one model for so long. What sort of work do you do with it.
            #446061
            John Haine
              @johnhaine32865
              Converted a S7 to CNC.
              #446085
              Steviegtr
                @steviegtr
                Did you put that on youtube, as I've seen one on there.
                #446092
                John Baguley
                  @johnbaguley78655
                  Posted by Steviegtr on 12/01/2020 01:29:46:
                  It's been used pretty much for everything within it's capacity. Mostly building steam locos but also making motorbike bits and telescope parts. Before I had a milling machine, all of my milling was done on it using a vertical slide.
                  I've now also got a Denham Junior that someone gave me so that's used for anything that won't fit in the Myford.
                  I've stayed 'faithful' to the Myford because it's a very good lathe and I've never felt the need to replace it smiley
                  Cornish Jack
                    @cornishjack
                    Bought mine second-hand in Swindon (thank you Mr Esson) about 30 years ago, after starting with a Unimat 3, from Sergeants (still have it!) The Myford is a 7b TriLeva, with clutch, long cross-slide and Cowells capstan tailstock feed. I fitted a 3 phase motor and vfd and have a mass of collets , TTA, dividing head , metal saw etc. Over equipped for the very little, poor quality output BUT, I thoroughly enjoy myself (most of the time!) Big problem is a 'tool Magpie Complex', so have (at last count, some 5 or 6 other lathes (Pultra, Unimat SL, watchmakers (plural) Cowells ME , etc.) For anyone potentially suffering a similar affliction, quantity (in my case) is NO substitute for quality! … Too old to reform!
                    Re. Myfords, for me, they were better documented than anything else (at the time) and expertise was (and probably still is) more readily available than for anything else. A good choice then, and no regrets now.
                    rgds
                    Bill
                    #446094
                    John Haine
                      @johnhaine32865
                      Posted by Steviegtr on 12/01/2020 10:39:18:
                      There's more than one, but I haven't.
                      #446097
                      Steviegtr
                        @steviegtr
                        Posted by John Haine on 12/01/2020 11:14:40:
                        So was it worth doing the CNC conversion. I bet it took a while setting up.
                        #446114
                        bricky
                          @bricky
                          I started with a perris and moved on to a ML 10,in 85 was given ab type Drummond I then trded in the Myford for a S7 in 87 vintage 57 without gearbox but a very accurate machine which Myford reground in 2005 .I then bought a S7 plus from Myfords closing down sale 2011 it was 10 years old.I had it seviced by Pete and Darron Made a full length taper turning attachment ,a large fixed steady ,a toolpost grinder,a quick change tool post and various other things that make machining easier.Using the myfords to their capabilities,mine are excellent but if I was building a large model I would need a larger lathe.
                          Frank
                          #446125
                          Harry Wilkes
                            @harrywilkes58467
                            Not done a lot to mine mechanically, fitted a VFD/motor, Tacho and DRO. It came with a load of extra's including a Dixson QCT have since purchased more toolholders and that's about it.
                            H
                            #446239
                            Steviegtr
                              @steviegtr
                              Posted by bricky on 12/01/2020 12:44:35:
                              Frank
                              Was that a Metric machine or still the old Imperial.
                              Steve.
                              #446244
                              John Haine
                                @johnhaine32865
                                Posted by Steviegtr on 12/01/2020 11:29:37:
                                Absolutely. Not too much time but done in stages over the years as I learned more.
                                #446247
                                Steviegtr
                                  @steviegtr
                                  Brilliant. Sounds like you built the ultimate small machine.
                                  #446259
                                  Hopper
                                    @hopper
                                    My son and I bought a clapped 1957 model ML7 for $400 at a garage sale some years ago and reconditioned every single piece of it. Nothing had been left undamaged by previous owner. Even had hammer marks on the bed. But did not need a regrind as within tolerance dimensionally. So did not cost a lot to rebuild. Fix rather than buy in most cases.
                                    Did the wide-guide conversion, cleaned up the inner bedways where the tailstock runs by using the carriage as a hand-driven shaper with a cutting tool clamped to the vertical slide for feed, then scraped the headstock bearings.
                                    Now it is a good serviceable, very accurate lathe. No measurable taper over a 6" test cut as measured with a standard mike. Will take a .100" deep cut without chatter. Drives carbide insert tooling no problem. Lovely little machine.
                                    Not a Rolls Royce to be sure, but good for what they were in the day, an affordable serious amateur's lathe. It'll do every thing I need for the foreseeable future. I use the fixed steady a lot to get around the small hole up the middle of the spindle. I find the Myford steady a little flimsy, the fingers can move under heavy load parting off 2" bar etc, so will probably make up my own heavy duty steady with brass-tipped 7/16" screws for fingers as I did on my old Drummond.
                                    Edited By Hopper on 13/01/2020 00:24:22
                                    #446279
                                    Clive India
                                      @cliveindia
                                      My story. About 5 years ago I was in the position where I had a Myford Speed 10 which I had bought to get me started in the hobby. I decided to upgrade and wrote a list of where I was trying to get to.
                                      This list was a Myford Super 7, gearbox, industrial stand, 2-axis DRO and variable speed.
                                      I found one which had the ind. stand, 3 phase motor, gearbox, but was long bed, advertised in ME and bought it.
                                      I added speed control first which enabled me to power it from single phase. I then added the DRO and, eventually, a tailstock read-out.
                                      Thus, it's about as good as it gets with a Super 7. It copes with all I need to do in model engineering. Occasionally I dream of getting a Harrison 250 or 300, mainly because it's a "Big Boys Lathe" and I used a Harrison at school 60 years ago, but then I realise I can do everything I need to with what I have. Incidentally, it's a whole lot easier to find a Myford in good nick than it is a Harrison, which are mostly very much factory-worn.
                                      Edited By Clive India on 13/01/2020 09:09:11
                                      #446301
                                      ega
                                        @ega
                                        Posted by Clive India on 13/01/2020 09:01:04:
                                        Sounds very nice; did it have a hardened bed?
                                        #446316
                                        ega
                                          @ega
                                          Posted by Hopper on 13/01/2020 00:21:46:
                                          That must have been a very rewarding project.
                                          Had you thought to try a Martin Cleeve-style bush-type steady?
                                          #446321
                                          David James Jenner
                                            @davidjamesjenner99025
                                            Bought my very first Myford a ML7 with stand, clutch and Quick-change gearbox just before Christmas 2019.
                                            Came with the manuals for the lathe and gearbox, a promotional pamphlet and a couple of books one by Mr Westbury and one by Mr Bradley.
                                            A collection of disassembled parts, so an interesting project!
                                            Looks to be all there, not sure of the age as the bed is well coated with grease preservative.
                                            Just need to find some time!
                                            I expect I'll be posting some questions here in due course!!
                                            Dave J
                                            #446330
                                            Clive India
                                              @cliveindia
                                              Posted by ega on 13/01/2020 11:14:23:
                                              Regret not – so nearly as good as it gets!
                                              #446396
                                              Steviegtr
                                                @steviegtr
                                                Well I started this thread with good intentions. Suppose we all think what we have is best. So what is not good about the Myford lathe. 1st thing that's springs to mind for me is that the Chuck does not lock on & the Morse is only MT2.
                                                #446398
                                                bricky
                                                  @bricky
                                                  The models from 2000 on did have a screw in the backplate of the chucks and faceplate which screwed into a groove in the register on the mandrel making it possible to turn towards the tailstock without worrying that the chuck would unwind.
                                                  Frank
                                                  #446401
                                                  John Haine
                                                    @johnhaine32865
                                                    Big bore lathe has MT4 – but beware that it won't take full length MT4 tapers! I bought one from RDG to make a test bar and it didn't fit – you'd think they would know!
                                                    And just now tried I think for the first time fitting the faceplate I bought new with the lathe. The bit of bent steel supposed to keep swarf out of the motor fouled the faceplate! Further investigation showed that when it was fitted they had to bend it to avoid it fouling on the cable gland on the motor – presumably a different motor pattern. If I bend it back to how it appears to have been made it clears the faceplate but won't fit over the motor.
                                                    Great British Engineering.
                                                    #446402
                                                    Steviegtr
                                                      @steviegtr
                                                      Is the motor mount the same as the older ones. As mine has 2 saddles around the neck of the motor , that can be slackened & the motor can be rotated on its mounts.
