One Year Chiming Bracket Clock–by C B Reeve
Home Forums Clocks and Scientific Instruments One Year Chiming Bracket Clock–by C B Reeve
  • #53235
    Peter Bell
      @peterbell11509
      Hi,
      I used the excellent ME index to find the relavant articles for the C B  Reeve One Year Chiming Bracket Clock  described briefly in early 1963. The index gives vol 128 issue 3208 p3, 3210 p70, and 3214, p 197 for the clock
      I managed to buy 3210 and 3214 but I suspect the the index is out by an issue as the item in 3214 p197 is about a gas engine. 3210 p70 is ok but it is the last article in the series.
      Is anyone able to look at the copies of ME around that time and confirm the actual start date or sell me the relevant ME or scan the relavant pages for me so that I could view the complete article?
      Thanks  Peter
      Peter Bell
        @peterbell11509
        #53236
        c
          @c
          Peter,
          I believe you have used the “searchable on line” version of the ME Index, which unfortunately does not show the “Category” field. Whilst the clock articles in issues 3208 and 3210 are categorised as “Horology”, the reference in 3214 is a “Correction”, seen towards the bottom of the third column.
          I will send copies of the item in issue 3208 directly to you.
          Regards – Chris.
          #53237
          Peter Bell
            @peterbell11509
            Chris,
            Many thanks for your reply and offer of the missing article, would never have found this C B Reeve clock without the index.
            Do you mean that I should have downloaded the  ME index before using it to search?
            Looked again in 3214 and sure enough there is an amendment for one of the photographs on p 197—right at the end of the gas engine article!
            Regards  Peter
            #53238
            c
              @c
              Peter,
              Article on its way.
              The “searchable on line” index is a wonderful resource, and the host is aware of this particular shortcoming; just takes time to change things!
              Chris
