I found a 1 – 13mm Albrecht chuck in the scrap bin at work yesterday, and when I got it home I found that it was seized solid. Hence the reason for it being in the bin. Years ago, having need of the knowledge, I looked up on the Interweb Thingy as to how to dismantle Albrecht Chucks, and so knowing already How To Do It, it was with me the work of a moment to dig out my aluminium split holder and strap wrench and unscrew the top. More applied battering removed further bits, until with a rush the last two components released their intimate hold….. and sprayed 4mm balls all over the workshop. Oh tut, tut, I didn't say.
Scrabbling about on the floor and the bench revealed all but three of the balls. 4mm… a relatively odd size… got plenty of 5/32" in the garage, perhaps they'd do… Just a minute! What's this tin labelled "4mm balls"??? There were at least a dozen!
Taking this booty back into the workshop, I spotted another Albrecht ball hiding behind the door. Then I saw another one.. and finally the last one was coerced from its hiding place under a box.
So that's what you have to do to defeat Mr Sod. You already have to have the missing parts you need in stock, and show them to him. Then he'll relent and allow you to find the missing parts. And if I hadn't had a box of 4mm balls, I'm pretty sure he'd still be hiding those missing balls, and wouldn't let me have them back until I'd been out to the nearest bearing shop and bought some.
