Olympic Class liners – building the engines
Home Forums The Tea Room Olympic Class liners – building the engines
Viewing 21 posts - 1 through 21 (of 21 total)
  • #34845
        This was on another forum today and I thought the photos may be of interest to some here, big boy engineering of the engines for Titanic etc.
        J
        #281334
        Anonymous
          It counts as a big lathe if you need a set of steps to reach the toolpost. thumbs up
          #281336
            Did you notice the zig-zag herring bone gears in one of the photos Andrew? You have not tried one of those yetsmile p
            #281337
            Phil Stevenson
              @philstevenson54758
              Jason, thank you so much for posting this. My grandfather was a turner at Harland and Wolff and worked on the Titanic, and probably her sister ships. I have very clear memories of him trying to get me as a small boy to understand the size of the pistons he worked on; he also told me of the news coming through of the sinking. No-one believed the story for some time, such was their faith in the ship. His voice was still full of emotion half a century after the tragedy. I have one or two of his tools, almost certainly from his time as H&W as he worked their all his life. I'll study the pictures in some detail – might even spot someone I know! Thanks again – very special pictures for me.
              #281347
              duncan webster 1
                @duncanwebster1
                Posted by Andrew Johnston on 30/01/2017 19:07:17:
                It's only big if there is a chair for the operator fastened to the toolpost so he can ride along with it!
                I think it was GEC who had a monster lathe with a headstock at each end and 2 saddles. Whether you could drop a tailstock (or 2) in the middle and use it as 2 independant lathes I'm not sure
                #281353
                Roger Williams 2
                  @rogerwilliams2
                  Fantastic pictures !. I think Harland and Wolff are still going, doing oil rig wotk.
                  #281359
                  Brian H
                    @brianh50089
                    I used to work at a company called Crossley-Premier Engines and they had a large lathe with steps up to the toolpost and also a chair from which the operator could control everything.
                    They also had a strange crankshaft finishing machine where the crankshaft was clamped to tables and the tool was in a holder that revolved around the journal!
                    #281385
                    Nick_G
                      @nick_g
                      Fantastic. smiley
                      Nick
                      #281389
                      Scrumpy
                        @scrumpy
                        What skills these people have no DRO or CNC in sight just outstanding tradesman, it makes one feel proud , when we led the world in heavy engineering
                        #281393
                        “Bill Hancox”
                          @billhancox
                          Posted by JasonB on 30/01/2017 18:37:45:
                          Excellent post Jason. I love this sort of pictorial engineering history. The photography is super for the period. I presume the marine engineers on the Olympic ships would have studied the drawings of the propulsion system prior to taking up their posts. They must have stood in the engine room (or should I say the engine great hall) in absolute awe when first encountering this completed and installed marvel of combined engineering skills.
                          #281409
                          Bob Rodgerson
                            @bobrodgerson97362
                            When I worked at The Wallsend Slipway and Engineering Company on Tyneside they still had some pretty old lathes that were used to machine very large diameters such as the steam turbine rotors for the Mauritania. These were I believe about 15 ft in diameter, the reason for them being this large was that they were direct acting and didn't use a reduction gearbox .
                            These large lathes had seats on the tool posts for the operator to sit in.
                            #281411
                            Ady1
                              @ady1
                              Worlds largest lathe for sale
                              Apparently you can go up to 3 miles between centres before the curvature of the earth affects your work
                              #281413
                              Ady1
                                @ady1
                                They tended to hang on to them back in the day
                                I recall reading about a battleship gun turret making lathe from around 1915 still around in one of the Scottish Shipyards in the 1970s, it had been sitting in a locked workspace within the shipyard for 60 years.
                                #281421
                                Anonymous
                                  Posted by JasonB on 30/01/2017 19:16:18:
                                  No, I had to have another look. I've no idea how to machine a double herringbone gear. An ordinary herringbone gear can be machined with a double ended shaper. Sykes were the main manufacturer of herringbone gear shapers, although Sunderland built a rival machine.
                                  It's not clear from the pictures but the apexes of the gear teeth look slightly rounded. Since the gears are part of the steering gear, and hence low speed, my supposition is that they are as cast, rather than machined.
                                  Of course now, with rounded apexes, they could be CNC'd.
                                  #281427
                                  Adrian Johnstone
                                    @adrianjohnstone89946
                                    The Kempton Park engines were of similar size to the Olympic and Titanic's (though designed and built by Worthington-Simpson quite a bit later in the '20's). As probably most folk here know, one of the engine is still run on ten weekends of the year – 2017 schedule: **LINK**
                                    A visit is very well worth while. You will feel the earth move, and you can get a tour of the non-operational engine.
                                    Adrian
                                    Edited By Adrian Johnstone on 31/01/2017 08:00:37
                                    #281442
                                    Roger Woollett
                                      @rogerwoollett53105
                                      Another site you might like.
                                      http://www.shipsnostalgia.com/guides/William_Doxford_and_Sons
                                      Lots of machines making marine engines.
                                      Edited By Roger Woollett on 31/01/2017 10:08:57
                                      #281449
                                      Hopper
                                        @hopper
                                        Posted by Roger Woollett on 31/01/2017 10:07:42:
                                        Great old photos. Thanks for posting.
                                        Now THAT's a ball turning attachment!
                                        #281452
                                        Scrumpy
                                          @scrumpy
                                          What a lovely post thanks Jason it brings back so many memories for me on visiting Devonport Dockyard as an apprentice some 51 + years ago and having a ride on the planning machine as it was cutting a profile for engine beds ,
                                          This was about 80 ft long and 30 ft wide they used to machine two beds at a time with 2 seats for the operator the tool holders were lifted in by chain blocks the travel was about one mile an hour health and safety would have had a field day I think it was made by hawthorn Leslie but I could be wrong
                                          #281456
                                            @mike89748
                                            Jason, I really enjoyed that. If you want a modern slant on big engines (diesel), go to http://www.test.swiss-ships.ch/berichte/berichte/waertsilae/Wartsila-RTA96C-engine-technology-review.pdf Sorry about the long and clumsy link – perhaps when somebody has a few minutes they could teach me how to condense it into just "Link".
                                            Link Added
                                            Edited By JasonB on 31/01/2017 12:19:36
                                            #281462
                                            Mark Simpson 1
                                              @marksimpson1
                                              Thanks Jason. Loved that.
                                              In the 80's and 90's NEI Parsons (Heaton Newcastle) and GEC large Machines (Rugby) were companies I regularly worked at (we provided the CAD system for them). They had some monster machine tools regularly working on parts of over 100 tons and bigger…
                                              I found this video from Parsons, some epic machine tools from about 9 minutes in,though the rest is also interesting…
                                              http://www.britishpathe.com/video/parsons-genius-of-power-reel-2-also-known-as
                                              Link added
                                              I know what the "elf and safety" conscious of today will be wincing a bit paternoster lifts, guys stood on the top of castings being poured, stood/sat on the toolpost of lathes and boring machines, no hi-vis…
                                              Edited By JasonB on 31/01/2017 13:09:43
