Yes but the picture and text tells you some sizes and you know all dimensions will be a round figure in inches and fractions.
So Bore = 1/2 in
stroke = 3/4 in
so use a piston about 5/8 in long
so make cylinder 1 1/2 long (picture looks a bit undersize hence comment about stroke in the text)
Either use 3/4 (5/8) round soldered to 3/4 x 1/2 bar or start with rectangular bar and file it to shape. Schools might have used it as an excercise on the shaper.
Flywheel = 2in
main upstand = 4x1x1/4
Flywheel support = 1 3/4 x 1 x 1/4
Cross piece = 1 1/2 x x1 x 3/8
Axle = 1/4 silver steel
Crank disc 1 1/2 x 3/8 turned down to 3/16 with boss of 3/16
Crank pin = 1/8 stainless
Piston rod would be better as 1/8 stainless with Mamod style end
Copper pipes 3/16 OD
Boiler – I don't have my copy available but there is probably an equivalent design in KN Harris Boiler Making book.
