I a building a PYRTE traction engine & have now started the cylinder. The spec calls for brass ( which I have) bored & then lined with phosphor bronze bush for the cylinder liner.
i am lucky enough to have a stockist of oilite bushes very near & can purchase 1 inch bore oilite bush of the correct length & diameter requiring a moderate amount of external work to press fit into the brass.
The cost , along with the bushes for the con rod, & eccentric, is little more than the postage for the raw phosphor bronze
Can someone advise if one can use oilite bushes, which would not need internal machining, for a cylinder liner, or is this a big no no
Thanks
