Oil Traps
Oil Traps
Home Forums Beginners questions Oil Traps
  • #49314
    Fred Nightingale 1
      @frednightingale1
      My first attempt at making a model marine steam engine is seen in the attached photo, However when people have seen the engine, they ask where is the oil trap?  I think when the original plans were drawn, polution was not seen as a problem. Does anyone know where I can get plans or is it so simple I should be able to design my own
      Fred Nightingale 1
        @frednightingale1
        Plans or Design for Oil Traps
        #49320
        Jeff Dayman
          @jeffdayman43397
          Looks  great Fred, sorry I don’t have any oil trap info just wanted to send my compliments.
          #49322
          Circlip
            @circlip
            Basically Fred, an oil trap is a can with an inlet and an outlet. The exhaust steam and crud goes in and the oil drops out allowing “Clean” steam to exit and up a chimney. Make sure the inlet from the engine points downwards so you don’t get a “Blow through” effect. When he designed it, I don’t think Basil?? thought about “The Enviroment”, he was just trying to get people re-interested in steam propulsion.
              Regards  Ian.
            #49323
            Fred Nightingale 1
              @frednightingale1
              Thanks for both your comments
              Currently my exhaust is fed into one of the boiler cross pipes and I thought the steam would go via the smoke box and out of the funnel. But I don’t seem to get any steam that I can see from the funnel
              Regards Fred
