Oil for Lathe GearBox
Home Forums Beginners questions Oil for Lathe GearBox
Viewing 21 posts - 1 through 21 (of 21 total)
  • #48776
    Codehopper
      @codehopper
      Hello All,
      Can anyone advise me of a suplier of Texaco Meropa 1000 Oil in small quantities? I have searched the Web without success. Quantities of 5 or 10 Ltrs would be ideal.
      I need to change the oil in my BD-1230 Lathe headstock gearbox but the only firms I have seen one the Web want to supply in 45 Gal. amounts which is far too much and very costly.
      Does anyone know of a good equivalent to Meropa 1000 ?
      Codehopper
        @codehopper
        #48778
        KWIL
          @kwil
          Are you sure it is Meropa 1000?  This strikes me as very thick oil for a headstock.
          #48781
          Codehopper
            @codehopper
            Hi KWIL
            Thanks for your reply.
            Yes, I wrote it down when I had the machine delivered new and the gearboxes were all filled in order to commision the lathe. Meropa 1000 is classed as an extream pressure oil specifically for gearbox use, and can go up to 1500 from as low as  about 100 if I remember correctly.
             Trouble is I don’t have a clue just how that compairs with other manufacturers oils, and in any case I han’t found anyone in the UK that supplies oil in small quantities (except shops like Halfords) for specialist needs, apart from one odd one on Ebay.
            Perhaps I will send them an email to see if they have an oil that compare’s.
            The Machine has a 2Hp motor so there is a fair bit of torque generated in the box and so needs a fairly good oil, It probably would compare with SAE 90 for car differentials, but I don’t know and I am no expert !!
            #48785
            KWIL
              @kwil
              My Harrison M300 headstock runs on very thin Hyspin AWS 32. The oil in the screwcutting gearbox is a 220 grade
              try  e mail to      ukcustserv@texaco.com   this is their office at Canary Wharf , London.
              K
              #48786
              Codehopper
                @codehopper
                Hi KWIL,
                Thanks for the link, I will try that.
                #48787
                Codehopper
                  @codehopper
                  Hi KWIL,
                  I just thought, your Harrison M300 will be a similar size to my Chinese BD1230 with possably an even bigger motor to the bd1230, so it is interesting that the Harrison uses such a relatively light oil. I have looked in the machine manual and it say’s to use Meropa 1000 in there as well.
                  #48788
                  KWIL
                    @kwil
                    Codehopper,  here is another link which shows Castrol range.  I think the 1000 refers to SG as in SG220 oil.  Castrol have a 1100.  Have a look here.
                    K
                    Edited By KWIL on 18/02/2010 16:29:39
                    Edited By David Clark 1 on 18/02/2010 18:33:31
                    #48789
                    KWIL
                      @kwil
                      Motor is 3hp on the Harrison M300.  AWS 32 [or NUTO 23] grade oil is a Hydraulic Oil, it really is like water.
                      #48790
                      Codehopper
                        @codehopper
                        Hi KWIL,
                        I just sent an email to the ukcustserv@texaco.com and it bounced! I will go on the web and see if I can pin down a newer email add.. The Castrol info looks good but again it is difficult to find small quantity suppliers.
                        #48858
                        DMB
                          @dmb
                          If I want anEP oil, I go to local carspares shop + buy `EP90` in a convenient sized plastic bottle. In fact, I make up a concoction of EP90, STP or Wynn`s (ultra sticky jollop) and a quantity of Molybdenum oil (black as yer hat! as its full of tiny balls of graphite). This I use as a slideway lube on the Myford. The sticky jollop makes it stay put, graphite gets into the smallest of spaces gives very good lubrication.
                          I do use  the recommended oil as supplied by Myfords for bearings but dont get through half as much since I ditched those awful leaky red oil pumpcans sold everywhere. I now use a quality `Reilang` oilcan – no waste!
                          Codehopper
                            @codehopper
                            Hi John,
                             I think that your idea is probably the way to go. The Meropa 1000 feels very like EP90 and going by what KWIL says about his Harrison M300 which has a bigger motor and uses a hydraulic oil that is like water in consistancy, then I can’t see that I should have too much of a problem with using EP90.
                            #49052
                            Dave Tointon
                              @davetointon92281
                              G’Day All,
                              Be carefull using modern automotive gear oil in older machinery. It contains lots of detergents and chemicals that will eat brass and bronze components. If you put it in an old Fergy gearbox it’ll destroy it in weeks!
                              Dave Tointon
                              #49061
                              Ian S C
                                @iansc
                                Just got some 30 grade for my BH lathe, been using multi grade until now. Ian S C
                                #49065
                                Codehopper
                                  @codehopper
                                  Hi Dave and Ian,
                                  Thanks for your post, my lathe is only a few years old and has all steel parts in the Headstock/gearbox so should be ok with something like EP90. Ian, was the 30 grade you mention a standard car type oil I wonder. I am guessing you mean something like 15W/30 or similar?
                                  #49095
                                  Ian S C
                                    @iansc
                                    No Codehopper, it straight 30 grade for small engines, it cost about twice as much as the 20/40 I was using before.I suppose today would be good for an oil change with the temperature in the high 20s(yesterday was over 30 and I couldn’t be bothered). Ian S C
                                    #49096
                                    Frank Dolman
                                      @frankdolman72357
                                           This is far from being the first “Oil” thread that we have had and the
                                         answers seem to be no more authoritative than usual.  Any old oil is
                                         better than none, no doubt, but the amazing differences between the
                                         solutions adopted above are horrifying when the damage that might
                                         be done to expensive and treasured machinery is considered.
                                           Could an eye be kept open for a “Workshop Practice” author to get
                                         it all sorted?
                                      #49103
                                      David Clark 13
                                        @davidclark13
                                        Hi There
                                        I have an article on lubrication to go into Model Engineers’ Workshop.
                                        It was written by Mike Haughton who was a chemist and worked with an oil company I believe.
                                        This will start in issue 163.
                                        regards David
                                        #49108
                                        Codehopper
                                          @codehopper
                                          Hello All,
                                          It may well be that you have had similar threads before but its not much use if you cannot supply the answer to my origional question without sniping.
                                           I asked for an answer as to where I could obtain the correct oil for my machine, I know what the correct oil is, but that is of no use if I cannot obtain it
                                          From the answers above it is obvious that other people have the same problem and have to resort to using whatever they can get their hands on.
                                          Likewise, an article in the Mag. does not help me at all because I know what Oil I need but just cannot obtain it.
                                          Someone out there must have been able to obtain oil of the correct type and correct amount for amateur use, ie in small quantities, but they are seemingly not willing to pass on the information.
                                          It looks like there is a good business opportunity  here for someone to start supplying oils of all types in small quantities .
                                          As regards to the question of duplicated requests for information, could the moderator perhaps sort out some sort of index so that people can go straight to a subject without trawling through all the various lists which can involve reading thousands of posts?
                                          #49110
                                          HasBean
                                            @hasbean
                                            Try here I’ve managed to get equivalent oils for my S7 as well as cutting fluids etc. very helpful.
                                            Paul
                                            #49113
                                            Codehopper
                                              @codehopper
                                              This is more like it ! At last someone with a usefull bit of information.
                                              I have sent them an email already so am keeping my fingers crossed.
                                              Many thanks Paul.
