Hi All
Anybody out there who can recommend an oil gun /pump that works on the little spring loaded cups found on Harrison/Colchester lathes.
I have two oil pumps in my armoury one is a (Colchester supplied pump) the other an old vintage car oil pump i believe, neither seem to generate enough pressure to unseat the ball and pump the oil through, probably pass there sell by date now, so i bought a couple different ones from Ebay and neither of them with do the job either.
Yep i have checked and cleaned the fittings and the balls pop open when pushed down with a small punch, using thin oil but even tried thicker oil nothing seems to work.
Its a right pain in the behind and theres got to be some solution to oiling the machine, anybody had the same issues and sorted out a workable oil gun or have a recommendation!!
Hopefully
Ian
