The pump O ring on my trolley jack started leaking. It too had gone hard and flattened, and I did not have the correct size in my box of assorted new seals. One comedian at a hydraulic company wanted £10 + postage for a single new O ring !
So I went back to my kit of seals and chose the one that fitted the groove, but had too big an OD for the bore. I mounted the O ring on a suitable shaft in an electric drill, (I do not have a lathe), and reduced the OD of the O ring using a file, until I could get it into the bore, where it made a nice tight fit. Pump and jack now work again.
(In case anyone is worried, this application is non critical, since if the modified O ring fails, all that will happen is the pump will stop working. If that happens the jack will simply refuse to pump up any further; the jack itself will stay where it was; held up by the non return valve, and I supplement the jack with axle stands).
