Odd bolt size
Odd bolt size
Home Forums General Questions Odd bolt size
Viewing 25 posts - 1 through 25 (of 31 total)
  • #402935
    AdrianR
      @adrianr18614
      I have just bought a cheep ebay engine hoist and the bolts that hold the castors on are M8. The odd thing is the head and nuts are 14mm across the flats.
      I am pretty sure they are metric as they have specification 8.8 on the heads.
      Googling bolt dimensions says they should be 13mm.
      Anyone have any idea why they are 14mm?
      AdrianR
        @adrianr18614
        #402939
        Hopper
          @hopper
          Various cars and motorcycles use 14mm heads on bolts and matching nuts. No idea why. I have had to buy a 14mm socket or spanner to complement a set that came without it more than once over the years.
          There seem to be various standards of metric, ISO, ANSI, DIN and a Japanese one. And Chinese manufacturers seem to have a pretty freeform approach to such things. They may have their own standards but they exist out of sight on the other side of the language barrier.
          Edited By Hopper on 31/03/2019 12:45:57
          #402941
            14mm on M8 is quite common but don't know why, maybe so all the old fogeys with 9/16 spanners like that size
            #402943
            Nick Wheeler
              @nickwheeler
              Posted by AdrianR on 31/03/2019 12:19:24:
              You've never worked on Japanese cars then?
              #402944
              Bazyle
                @bazyle
                the 8.8 is a strength designation. The reason for having different sized nuts is because a normal spanner set does not include two 13mm spanners. So if you want a spanner at each end to tighten it it is extremely helpful to have different sizes. The same is found occasionally in imperial bolts on cars that have been designed by someone who actually does his own servicing.
                #402946
                  Posted by JasonB on 31/03/2019 13:18:48:
                  14mm on M8 is quite common but don't know why …
                  … it lets them get away with using bigger clearance holes devil
                  not done it yet
                    @notdoneityet
                    The sensible reason for the bolt head being a different size to the nut is so that only one set of spanners need be used for maintenance. Nuts usually get damaged, so replaced more often than the bolt, so they are the standard size and the bolt head is sensibly one size larger.
                    #402953
                      I've got some 14mm M8 nuts so that rules out just the bolts being bigger.
                      Seem to remember one item I bought had four M8 flange nuts – two were 13mm and two 14mm and they fitted onto studs so only one spanner neededcrook
                      #402962
                      AdrianR
                        @adrianr18614
                        The reason i noticed it was that i am in the middle of relocating and of course my 14mm spanner is at my other place 160 miles away. At least screw fix have some cheep spanners.
                        Will be great when the workshop build is finished and I can move it all.
                        #402983
                        alan-lloyd
                          @alan-lloyd
                          the head size was reduced way back in the 70s maybe 60s to save metal, what you have was probably made on old presses, spanners were 10×14 now I think 10×13 is more common
                          #402987
                          vintage engineer
                            @vintageengineer
                            If you want odd bolts, try working on pre-war French cars! They made up their own sizes and pitches!
                            #403005
                              Posted by Bazyle on 31/03/2019 13:31:17:
                              Back in the 70s/80s Ford perfected this approach to the extent that you could undo all four bolts on a typical part simultaneously because they all had different heads…
                                Posted by Neil Wyatt on 31/03/2019 22:11:01:
                                … to the extent that you could undo all four bolts on a typical part simultaneously …
                                Assuming that you were quadridextrous angel
                                … one-man-band ?
                                Edited By Michael Gilligan on 31/03/2019 23:36:41
                                #403020
                                clogs
                                  @clogs
                                  repaired a Chinese motor scooter no so long ago and quite a few of the nuts and bolts had 5 corners around the engine and ancilleries…..
                                  standard threads tho…..everything got replaced with Stainess..
                                  had fun getting the seized fixings undone……hahaha………well funny now……..
                                  #403021
                                  Nicholas Farr
                                    @nicholasfarr14254
                                    Hi 13mm for an 8mm bolt is only a standard. I've seen 8mm bolts with 14mm heads a number of times and I've even come across them with a 12mm heads. Other standard sizes also have variables, like 12mm with 18mm heads, 10mm with 16mm heads. It is often due to their usage for a manufacture to which size heads are used and often down to cost if you produce equipment using many thousands of bolts per year.
                                    Regards Nick.
                                    #403110
                                    vintage engineer
                                      @vintageengineer
                                      Modern French cars are doing this to stop no dealer mechanics working on them!
                                      Posted by clogs on 01/04/2019 06:18:23:
                                      #661569
                                      Geoff Glass
                                        @geoffglass80961
                                        Apparently, 14 mm A/F was an old DIN standard, but they are still available
                                        #661735
                                        Howard Lewis
                                          @howardlewis46836
                                          My impression is that, as a rash generalisation, European cars tend to use 8, 10 13, 15, 17 mm A/F hexagons while oriental seem to prefer 8, 10, 12, 14, 17 in many cases.
                                          The idea of of using different A/F sizes for bolt head and nut sizes, obviating the need for two spanners of the same size is a sensible and practical design feature.
                                          The different sizes will not affect the clamp (tensile / compressive ) load applied since this is produced by the torque applied to the fastener. Given the same material and friction conditions, a M8 capscrew will produce the same clamp load as a 13mm A/F headed M8 bolt when the same torque is applied.
                                          A screw thread can exert quite large forces. A thread with a 1 mm pitch can equate to a very long lever.
                                          Driven by a spanner 100 mm long, ten revolutions will lift a load by 10 mm. But the end of the spanner will have travelled (100 x pi x 10&nbsp mm so effectively, the load has been lifted 10 mm by a lever which is 3141.6 mm long. A Mechanical Advatage of 314! A 3 metre long crowbar will lift quite a load
                                          #661737
                                          duncan webster 1
                                            @duncanwebster1
                                            It doesn't work quite like that. Most of the work done turning the spanner goes into friction between the male and female thread and the face of the head against the abutment. This is why torque settings on bolts aren't that reliable, change the friction coefficient and you change the clamping load. Finer threads are more affected as the rotation for a given axial movement is more.
                                            #661740
                                            File Handle
                                              @filehandle
                                              Some open ended spanner and ring spanner sets did have two of each size, except for the smallest and largest sizes, but not true for most combination and socket sets. Although I do have a socket set that does duplicate sizes having 6 and 12 point sockets.
                                              #661749
                                              Howard Lewis
                                                @howardlewis46836
                                                I did say friction conditions, for that very reason!
                                                Often torque settings are qualified by specifying the lubrication, or otherwise of the fastener and its threads. Presumably after having investigated the results from a particular combination of materials and lubrication.
                                                If you want to know the clamp load applied, use a load cell, strain gauge the components being clamped, or after some experimentation, tighten the bolt to give a known extension.
                                                Forgot to mention Pilgrim nuts for large fasteners!
                                                The ultimate is probably tightening until the fastener just goes into yield, and takes a small, permanent extension.
                                                This is a most efficient use of a fastener, and should produce consistent tensile loads.
                                                I found that W range fasteners, into cast iron, would give consistent results, lubricated with soluble oil (Which we deliberately varied between 5 and 20% concentrations ).
                                                For a variety of reasons, it took six months before simultaneous yield tightening of 32 fasteners was considered safe to be allowed in high volume production. Thereafter problems were almost unknown, and gasket failures dropped to zero.
                                                Edited By Howard Lewis on 27/09/2023 16:54:17
                                                #662066
                                                Nigel Graham 2
                                                  @nigelgraham2
                                                  Obviating needing two spanner sets for servicing machinery is one thing, but the flanged bolts sold nominally as building components seem to be a law unto themselves, heavily tapered and not the normal A-F size for the ISO-M Coarse thread.
                                                  While I've yet to identify properly the nut on my ML7's rear tool-post's main stud!
                                                  #662091
                                                  Howard Lewis
                                                    @howardlewis46836
                                                    The taper is the draft angle of the forging, to allow the product to be removed from the die, for the same reason that castings have a draft angle on internal and external faces.
                                                    Because of the age of the design (1947 saw the ML7 launched ) the fastener on the Myford is likely to be a BSF size. The stud for the front too[post is 7/16 BSF, from memory, so ithe rear one is likely to be something similar with a Whit form thread.
                                                    Edited By Howard Lewis on 29/09/2023 21:55:43
                                                    #662093
                                                    Jon Lawes
                                                      @jonlawes51698
                                                      My Gipsy Queen engine has metric threads with imperial widths across the nut and bolt heads. That threw me for a while.
