O rings
O rings
Home Forums Materials O rings
  • #593479
    Kiwi Bloke
      @kiwibloke62605
      O rings, performing static sealing duty, on hydraulic rams on the front-end loader on my tractor fail slowly, apparently by extrusion. The design could have been better: seal back-up rings would probably have helped. Unfortunately, modification isn't practicable. The loader gets abused and treated badly. Unfortunately, my bad behaviour probably also can't be modified…
      At present, common-or-garden nitrile rings (2.25 X 0.125 in) are in place. Does anyone know whether a different material might have greater resistance to extrusion?
      Kiwi Bloke
        @kiwibloke62605
        Failure by extrusion
        #593480
        jimmy b
          @jimmyb
          Would "X" section rings be any use?
          Jim
          #593481
          Hopper
            @hopper
            Viton O rings seem to seal better on old motorbike applications. But no idea under hydraulic pressure.
            Edited instead of mine, JB
            Edited By JasonB on 08/04/2022 07:03:21
            #593486
              Viton also resist some oils better and like nitrile come if different hardnesses the harder the higher the pressure they can take
              #593492
              HOWARDT
                @howardt
                You could try a harder material. The extrusion gap between the two parts increases with harder material. Dependant on o-ring x section and groove form you may be able to use a different form of seal, contact a seal manufacturer with dimensions and see what they can offer.
                #593508
                Ex contributor
                  @mgnbuk
                  Change your design to include PTFE Back-up rings on the side of the O-ring suffering from extrusion.
                  PTFE backup rings
                  Nigel B.
                  (just noticed your comment re-not feasible to re-design – sorry !)
                  Edited By mgnbuk on 08/04/2022 10:04:13
                  #593603
                  old mart
                    @oldmart
                    The suggestion for a harder material from HOWARDT would be a good start. Either the clearances are too great, or the O ring material is being softened by the hydraulic fluid. Viton is likely to be harder than nitrile, and much more resistant to hydraulic fluid.
                    https://simplybearings.co.uk/shop/Seals-O-Ring-Seals/c19_4501/index.html
                    https://simplybearings.co.uk/shop/Seals-O-Ring-Seals-VITON-O-Rings/c19_4501_4706/index.html?selection=VITON+Rubber+O-Rings
                    Edited By old mart on 08/04/2022 21:15:00
                    Edited By old mart on 08/04/2022 21:21:47
                    #593651
                    AdrianR
                      @adrianr18614
                      Does your ram have guide rings? are they worn? if they are it increases the gap on one side which makes extrusion worse.
                      You could also look at the SKF DPV seals https://www.skf.com/binaries/pub12/Images/0901d196805e7f09-17145-EN-_Piston-seals_tcm_12-289553.pdf#cid-289553
                      Adrian
                      #593806
                      Kiwi Bloke
                        @kiwibloke62605
                        Thanks for the suggestions, folks. I'll see if it's possible to get more robust O rings, but we have to take what's available here in 3rd-world NZ – a seriously restricted range of engineering stuff in a country without an engineering heritage… I know the rest of the world is but a few clicks away, but I'm old-fashioned, and prefer to shop conventionally.
                        To clarify: the O ring seals the end of the cylinder to the body of the cylinder, so it's not a sliding seal. There is no true piston seal in this super-crude (but elegantly simple) design (Kiwi engineering at its best/worst). The dynamic seal is located in the removable end of the cylinder, acting on the ram's outer surface. There's also a wiper seal. The O ring sits in a groove in the seal-carrier (the removable end of the cylinder), and seals against the OD of a turned-down section of the cylinder, the seal-carrier being screwed onto the cylinder.
                        The designers should have given the O ring an easy life, but it's exposed to full hydraulic pressure, including the effects of a bucket-full of soil, etc., bouncing around when driving over uneven ground. Goodness knows what the peak pressures can be. I suppose it's doing quite well, all considered. Ideally, the O ring's groove should be widened, so a back-up ring can be fitted, but that takes time, whereas replacing the O ring takes minutes…
                        Edited By Kiwi Bloke on 10/04/2022 07:04:19
                        #593813
                        noel shelley
                          @noelshelley55608
                          Hi KIWI, For harder rings ask for shore 90, the nornal O ring is shore 70. It might be worth trying a metric ring of slightly larger dimension eg 3.5 mm section X 50mmID. For what they cost it's worth a try. Noel.
                          #593876
                          old mart
                            @oldmart
                            Viton is most easily obtained in 70 shore hardness, but as it is likely to be more resistant to hydraulic fluid, it will not tend to soften and be extruded like the nitrile you are using.
                            You haven't mentioned the name of the hydraulic fluid you are using.
                            #593884
                            Neil Lickfold
                              @neillickfold44316
                              If you go to Seal Imports, one in Hamilton NZ, they make seals on a special seal making lathe. They used to have a hydraulic engineer working there who designs seals and know all about the appropriate material to be using. Their prices are very reasonable as well for specially made seals too. Our work gets them made there.
                              There is also another seal making place in Auckland, not sure if it is connected to Seal Imports or not.
                            Home Forums Materials Topics
