O ring suppliers
O ring suppliers
Home Forums General Questions O ring suppliers
  • #93537
    mick
      @mick65121
      I've been looking on-line for over half an hour for an "O" ring supplier, I only need one 3/8th. or 9.50mm O/D "O" ring, I'm quite happy to buy the minium quantity of 20 but not too happy about the minium order of £10 + VAT + £3.75 p&p Any body know of a friendly supplier?
      mick
        @mick65121
        #93538
        Flywheel
          @flywheel
          Why not try your local Bearing/oil seal supp;ier they will probably sell you just the one
          #93539
          Windy
            @windy30762
            ALDI sell boxes boxes of imperial and metric o rings if not in now they eventualy come back in the store.
            Polly might be able to help
            If desparate PM me with dimensions id od and diameter of cord as long as it's not a special material required (silicon?) will see what I have.
            Windy
            Edited By Windy on 02/07/2012 11:53:59
            #93540
            Roger Woollett
              @rogerwoollett53105
              I have used Simply Bearings in the past and found them very reasonable. They list 9,5 i/d, 12.5 o/d nitrile rings as £2.29 + VAT for 2off. Postage is £1.50. They have a big range and a choice of materials.
              Roger Woollett
              #93543
              Terryd
                @terryd72465
                Hi Mick,
                Try Macc models, I have bought quite a few 'O' rings of various materials and sizes and he sells singles. It is worth looking through his extensive catalogue to stock up on a few items to make P&P worthwhile as he charges by weight. In fact he is showing a 3/8" od, 1/4" id silcone 'O' ring for 29p at the moment here.
                Terry
                Edited By Terryd on 02/07/2012 13:21:12
                #93545
                DMB
                  @dmb
                  Hi Mick,
                  Stuff the postage, put them on shopping list for xbns., e.g., Guildford next weekend, Bristol in Aug.
                  If you live near enough, Ardingly showground also next weekend – lots of micellaneous stands there. Bound to be one flogging black rings.
                  Gordon W
                    @gordonw
                    I usually get this sort of thing at the local garage (Car repair ) or tractor place. Generally have selection boxes and different materials.
                    #93548
                    Phil Ashman
                      @philashman88468
                      I've bought O rings from this company,
                      I think they come in bags of 20, but they're not too expensive, about £7 for 9.5mm.
                      Phil
                      #93549
                      Mike p
                        @mikep
                        Hi, I have just looked in Blackgates Engineering catalogue and find the 3/8" od listed at 36p. I have used them before and found them most helpful. My catalogue is for 2009 I doubt they have increased by much. Their phone No. is 01924 466000  or http://www.blackgates.co.uk
                        Mike p
                        Edited By Mike p on 02/07/2012 16:30:35
                        #93551
                        mick
                          @mick65121
                          Thanks to all, knew I could count on the collective grey matter as usual.
                          Mick
                          #93554
                          Jon
                            @jon
                            Depends what you want and where you get them from, the sizes are nearly all different even though conform to BS.
                            How many do you want in nitrile or viton and cross section? i can post you some.
                            #93574
                            Sub Mandrel
                              @submandrel
                              Try screwfix or machine mart for selection boxes for abouit £5-7. IIRC they are metric, but in small steps so you will probably find one you can use with little adjustment.
                              Chronos do better quality ones in small quantities.
                              Gordon A
                                @gordona
                                Greetings Mick,
                                You could maybe take a look at this place. Not used them myself, but they appear to have a good range of products.
                                http://www.polymax.co.uk/
                                Gordon.
