I have a hand pump on a Stuart 504 boiler. The pump does not seal over well. It used to have graphite yarn as a seal but this had dried and gone brittle so replaced with an 'O' ring. Still not a very good seal. I am thinking of putting an 'O' ring on the piston itself.
The piston is 0.624" dia. and the bore is nominally .625". I have silicone 'O' ring which is .625" OD and .4375 ID.
Is this a good idea and if so what groove dimensions should I use (width and depth).
Many Thanks,
Colin
