Nut sizes imperial measurements, disorientation!
Home Forums Beginners questions Nut sizes imperial measurements, disorientation!
Viewing 7 posts - 26 through 32 (of 32 total)
  • #635241
    Howard Lewis
      @howardlewis46836
      Drain Rod threads appear to be Whit form, 7/8 or 3/4" ( From poor memory A While since i made an "unstopper" using broom handle and the rubber disc, for our daughter )
      Nigel Graham 2
        @nigelgraham2
        Yes: Drain Rod Threads are 7tpi BSW form! I can't recall the diameter without going and dragging them out to measure, but I don't think it's as large as 7/8" .
        How do I know?
        I made parts for a pump for a caving application, with a drain-rod section as its piston-rod / handle. It starts a siphon to drain a short "sump", a pool totally filling the passage with water, like a sink-trap.
        I turned a brash bush with male thread, to fit the plastic piston that works in a short length of 150mm PVC drain-pipe. Calculating the wheels for an EW lathe with 20-65 X 5T change-wheels, two-stage only and 1/8" lead screw, was interesting.
        I used that lathe too as a 2-axis dividing-head for drilling about 130 holes in a plastic tube for the pump's inlet strainer: using a hole through a brass block in the tool-post, to guide the bit in a small battery-drill. Workpiece between centres.
        Fibre-tip pen marks on the 60T change-wheel on the spindle as angle indicator sighted against a headstock feature on the headstock as their "pointer"; similar but separately on the lead-screw for lengths. Guide-block against the work as angular brake, normal saddle lock for lengths.
        #635284
        bernard towers
          @bernardtowers37738
          Drinks bottle threads?
          #635287
          Bdog507
            @bdog507
            Good evening all.
            The thread I had in mind is the Schrader valve thread. Invented by a German in the USA…..Says it all really!
            Cheers.
            Stewart.
            #635289
              Is it Unique though as there are several different sizes of the Vg thread form and the common tyre size Vg8 is just a 60deg 32tpi thread
              I would have said threads like Edison, plastic bottle and glass bottle forms are fare more unique in shape though again have several size options
              Edited By JasonB on 27/02/2023 19:26:28
              #635290
              Bdog507
                @bdog507
                Good evening all.
                As far as I know there's nothing else that uses it. Bloody Yanks!
                Indeed bottle threads are very unique in form, and there are considerable variations. Think how many times a day bottles get unscrewed vs how many tyres are pumped up. I wouldn't like to be the chap who had to count them!
                Cheers.
                Stewart.
                #635310
                Nigel Graham 2
                  @nigelgraham2
                  My candidate thread in all our homes and probably operated by more people than is the tyre-valve thread, is that used on glass jam-jars:
                  A rounded-top, flat-bottom profile, multiple-start breech-thread; i.e.perhaps 4-start but cut through to give a quarter-turn action for a female thread that is no more than tabs!
