I appreciate that and do realise that the fine 9mm thread is very odd, but a quick internet search did find them, but not in the UK.
the actual application size is M9x1 x 7mm long so even a 30mm bolt would do so easily cut down.
For those interested im making a traction control sensor for a friends National Hill Climb car – on the front hubs there are retaining rings which hold the front wheel bearings in place – the rings have equally space 8mm holes around the outer edge – the bolts are needed for the Hall effect pick up – as the hole is already at 8mm next best approiach is to tap them 9mm and as the ring is only 7mm thick a nice fine 1mm pitch thread seems the best way.
They will be fitted and then the head machined down so it forms a square rather than hex as the pick up is much happier with the flat edge of the square than the potentially sharp edge of a hex…. a lot of work and the added work of having to make 30 bolts and thread each one is adding more work……
