Number drills?
Number drills?
Home Forums Workshop Tools and Tooling Number drills?
Viewing 23 posts - 26 through 48 (of 48 total)
  • #616396
    Bo’sun
      @bosun58570
      Posted by Dr. MC Black on 06/10/2022 23:40:52:
      If Bosun cares to visit me (Herts), he can use my gauge to measure his drills
      MC
      Thank you Dr,
      While I only live in Essex (not far away), I'd like to have something on hand for future use if need be.
      Rod Renshaw
        @rodrenshaw28584
        Jason
        Thanks for the thought but I have drills in sets in cases, I was just wondering if it were possible to buy a "stand" , for metric drills of the type which used to be common, and which held sets of drills sticking up from a block or ring like shape and from which one could select drills without having to open the box. I have often seen second hand stands on sale at shows and on ebay etc but these all seem to be older ones sized for Imperial or number drills. It's only a whim or bit of laziness really and I suppose I could make one by drilling lots of holes in a block of wood or alloy etc but it sounds like a lot of work with all the drill changes and size marking required.
        Rod J
        Thanks for the link, That is the sort of thing I meant but looking at the description carefully it seems it has multiple holes for multiple sets of nail drills and I was hoping to find a stand intended for a set of metric drills with markings as well as holes.
        I will keep looking for now, I wonder what engineers in fully metricated countries do, do they all keep their drills in boxes?
        Regards All
        Rod R
        #616415
          The other Rods round one looks to have the holes numbered in 0.1mm steps. Confirmed by the description " 91 holes: 1mm – 10mm (difference 0.1mm)"
          As for opening boxes, I have removed the lids from by boxes and just have them stood where they can easily be accessed. My stub ones are in strips of wood screwed to the wall.
          Edited By JasonB on 07/10/2022 17:11:27
          #616423
          Bazyle
            @bazyle
            For those with the equipment there are plenty of drill holder options for 3D printing or laser cut ply.
            At my first job all small stores requisitions were supplied in little brown envelopes, about 3"x2" which now fit in a cardboard box like a card index. I still find this the most simple system when you don't have a complete set though some envelopes are now tatty as nearly 40 years old.
            #616427
            Dr. MC Black
              @dr-mcblack73214
              Posted by Rod Renshaw on 07/10/2022 12:30:11:
              As this thread has drifted a little from drill gauges to drill stands and boxes, can I ask if anyone knows where one might buy a metric drill set stand for metric drills by 0.1mm sizes. My sets are in boxes and it's a bit of a fag to keep opening and closing the boxes.
              Thanks
              Rod
              Try RDG Tools:
              https://www.rdgtools.co.uk/cgi-bin/sh000001.pl?WD=stand%20drill&PN=Drill-Stand–British-Design–0.5mm—14mm-in-0.5mm-steps-84522.html#SID=207
              MC
              #616428
              Dr. MC Black
                @dr-mcblack73214
                Posted by Michael Gilligan on 07/10/2022 12:33:49:
                Posted by Dr. MC Black on 07/10/2022 12:03:15:
                I have NOT been able to find empty drill indices at a sensible price for any type of drills, Metric, fractional, numbers, letters, etc.
                Just curious … What do you consider to be a sensible price ?
                I have seen them advertised at over £17.
                I would consider a Fiver or less to be sensible – depending on which box was offered.
                I have bought 0 to 10 mm by 0.5 mm in the past for around two or three pounds
                MC
                #616430
                Anonymous
                  I live in the United Kingdom – NOT in Europe
                  Really?
                  #616431
                  Dr. MC Black
                    @dr-mcblack73214
                    Posted by Bo'sun on 07/10/2022 13:32:31:
                    MC
                    Thank you Dr,
                    This gauge from Proops looks suitable:
                    https://www.proopsbrothers.com/steel-twist-drill–machine-tap-gauge-nf–nc-decimal-equivalents-m0419-1600-p.asp
                    The enlarged image shows holes labelled 1 to 60.
                    At £2.40, it's NOT a huge investment if it turns out to be wrong.
                    MC
                    #616436
                    Dr. MC Black
                      @dr-mcblack73214
                      Posted by Peter Greene 🇨🇦 on 07/10/2022 18:37:30:
                      Really?
                      I assure you that I know where I live.
                      If the Almighty had wanted the British Isles to be part of Europe, he would NOT have given us the English Channel!
                      MC
                      #616457
                        Posted by Dr. MC Black on 07/10/2022 18:27:37:
                        I would consider a Fiver or less to be sensible – depending on which box was offered..
                        I will be happier if mistaken, but …
                        I think you will be lucky to find anything worth using at that price.
                        MichaelG.c
                        #616478
                        Nicholas Farr
                          @nicholasfarr14254
                          Hi, I've got a Dormer number drill stand 1 to 60, which was my father's, I don't use it really, but it does remind me of my father's shed and my father using them, and I can remember all the holes were populated when I was a boy, it's got a few of the larger drills in it, but they are not the originals, they were in a tin of various drills, which! if I didn't take them home from my last day job, they would be binned, but only number 5 is a Dormer HS. I do have a full set from 1 to 60 which are in the usual swing up lid type box, but they aren't Dormers, but they are good quality, which I bought from Rotagripe at an exhibition many years ago, although I've had to replace a few smaller ones which I've busted.
                          Regards Nick.
                          #616485
                          Bill Phinn
                            @billphinn90025
                            The 100-hole round plastic ones look ideal, but I wonder whether the fact that they're rotatable, plastic [and therefore light] makes them inclined to move about undesirably when you're getting drills out or putting them back.
                            Can Roderick let us know, because the idea looks appealing at least?
                            I've got a large, recentish Dormer drill stand in plastic for metric drills, including holes for many of the tapping sizes, but it's rectangular and has a substantial footprint, so it doesn't move about when you use it.
                            Edited By Bill Phinn on 07/10/2022 23:14:23
                            #616486
                            Dr. MC Black
                              @dr-mcblack73214
                              Posted by Michael Gilligan on 07/10/2022 20:13:13:
                              MichaelG.c
                              Since I have all the empty boxes that I need and now mostly filled with drills, I am NOT looking to buy more.
                              I find it useful to have various Letter, Number and Fractional drills because sometimes a drill of an odd metric size is needed and one of the above is a closer match than a metric drill (which I have only in whole and half millimetre sizes)
                              MC
                              #616489
                                Posted by Dr. MC Black on 07/10/2022 23:25:02:
                                Apologies for my misunderstanding of your earlier posts blush
                                Dr. MC Black
                                  @dr-mcblack73214
                                  Posted by Michael Gilligan on 07/10/2022 23:32:53:
                                  There's no need to apologise
                                  I was able to buy boxes some time ago and keep drills in them indoors rather than in shed-workshop (where they might go rusty)
                                  Nowadays, one can buy sets of drills loose and complete in boxes but empty boxes is a challenge.
                                  I don't want to keep drills in a stand because (a)they will get dusty and dirty and (b) I would have trouble picking them up if I knocked the stand over.
                                  I guess there's nobody else who is clumsy!
                                  #616553
                                  Roderick Jenkins
                                    @roderickjenkins93242
                                    Range is from 1 to 10mm in 0.1 steps and then 0, .5 and .8 up to 12. The drills fit fairly firmly in the hols so a 2 hand job to extract (one to steady the stand) but on the plus side they will not fall out if the stand is knocked over. These drills are mostly tapping sizes for M coarse, BSF, BSW and BA plus some ME sizes. I couldn't get the 10mm plus drills in stub length sad. My jobber length drills in metric(1-5.9) and (6-10) in 0.1 increments and 1/16 to 1/2 in 64ths live in the metal cases they came in.
                                    Works for me,
                                    Rod
                                    #616580
                                    Rod Renshaw
                                      @rodrenshaw28584
                                      Thanks Rod J,
                                      that looks to be the very thing now you have explained it.The description on Amazon had me fooled.
                                      Rod R
                                      #616609
                                      Dr. MC Black
                                        @dr-mcblack73214
                                        Posted by Roderick Jenkins on 08/10/2022 12:32:45:
                                        [snip]
                                        Rod
                                        If the stand is knocked over and the drills don't fall out, will the little ones bend or break?
                                        MC
                                        #616613
                                        duncan webster 1
                                          @duncanwebster1
                                          Posted by Dr. MC Black on 07/10/2022 18:44:46:
                                          Really?
                                          MC
                                          If you go back not all that far in geological terms there was no English Channel, mainland Britain was a peninsula, you could walk to Holland. Perhaps the Almighty changed his mind.
                                          #616618
                                          bernard towers
                                            @bernardtowers37738
                                            img_2944.jpgwhy bother with a drill gauge you must own a digital cal and as for drill stands I have used old pistons in the past and offcuts of 50 mm aluminium. the piston stand is in point 1s on the outer ring and .05 on the inner.Sorry about the orientation but it seems to be a left hander thing.img_2943.jpg
                                            Edited By bernard towers on 08/10/2022 19:39:23
                                            Edited By JasonB on 08/10/2022 20:15:17
                                            #616622
                                            bernard towers
                                              @bernardtowers37738
                                              Thanks Jason sometimes it works sometimes not.
                                              #616625
                                              Nicholas Farr
                                                @nicholasfarr14254
                                                Hi Bernard, I like the large one with the numbers stamped on the side, nearly tempted to make one myself, just for the artistic look.
                                                Regards Nick.
                                                #616678
                                                bernard towers
                                                  @bernardtowers37738
                                                  Yes looks ok, started off as a 5.1 litre diesel piston,a leftover from engine building days.
