After nearly melting yesterday when the temp in both the carport and workshop went over 30° I decided that was it, no more purgatory!
I went straight into the lounge and hauled the aircon unit that's been sat there since the last heat wave which must have been 10 years ago, and only used once since, into the workshop.
It's a proper portable one, and not the waterfall type that saturates the air with moisture – been there and tried that years ago but soon got rid of it, as breathing became unpleasant.
This unit has a plug in flexible duct of 100mm diameter, to duct the hot air outside, so I needed to find a way to vent said air, and the only easy place to cut a suitable hole was in the garage side door at the rear of the property, but I had to wait for the grill, with gravity slats, I ordered to arrive, which it did this morning.
I soon had that in place, but the aircon ducting was not easy to connect and did not stay in place so a hunt was on to make an adapter of some sort.
eBay only produced a bit of stainless tube, so had another search around the house and came back to the Amarula tin plate tube that the bottle comes in.
I has dismissed it previously as not being suitable, but after some thought this time, decided it could be used so a 2.1/2" long slit at the joint was made, and a piece of the tube 5" long sliced off.
Suitably deburred and it squeezed into the ducting easily with a firm hold, the other end fitting into the vent perfectly, but a bit wobbly so self tappers to the rescue and all is now solid.
That's why I don't throw anything away unless its proper useless junk.
My philosophy has proven itself today – big time.
Geoff – A cool workshop from now on!
