Jason I rather agree – you do have to set the rivet, or the plates.
Also, as a complete beginner to riveting, I found it a 3 handed job. If you hammer the rivet too hard, it deforms the plate and makes it curve, and it was very difficult to get the whole thing to start straight anyway.
I had a compressor – and a boilermaker at work said that professionally they used air, so why didn’t I? I bought an air hammer, (Axminster £20) and then put the cup/domed shape into the end of the hammer bit (its fairly tough, but machinable and you can use a ball nosed slot drill with plenty of coolant).
Pop the rivet in, you secure the head in the snap located in a vice – that’s the anvil. Set the air regulator to about 70psi (not too meaty), press the air hammer firmly agin the protruding rivet shank, and pull the trigger.
1 second later, you have a perfect double domed rivet and no damage to surrounding metal.
The shank sticking through needs to be a smidgen longer than dia. So for a 1/8 rivet about 3/16 of shank does the job. Doing a traction engine tender, I now have various “sets”. Nice short 2″ one, a 6″ long one and one nearly 13″ long to get into the bottom of the tender tank. teh long ones are made from hardened silver steel, socketed into an air hammer base.
Very easy!
I’ll have a go at this countersunk version
Edited By meyrick griffith-jones on 27/08/2009 18:28:16
