Posted by David Clark 1 on 04/08/2009 17:07:16:
The cylinder pitch is 6inches to centreline and runout is 3/8 down.
I was asking about the cylinder in relation to the holes for item 10, see the last half dozen posts in the “first project” thread.
If drawn using the dimensions on the ME Drawing the six cylinder mounting holes come out further back than shown.
Can you confirm that the 9/16 dimension mid way along the top is correct as it is drawn far larger than the 9/16 bolt spacing and looks more like 3/4, if it were 3/4 this would put the cylinder fixing holes and holes for item 10 all in the right place.
Maybe the original drawings could be added to the articles section.
And while I’m on there does not seem to be any length given for the firebox support, it is just shown as a dotted outline on the frame drawing and the “1/8″ clear locate from frame” note about the central hole is where the dimension should be.
Jason
Edited By JasonB on 04/08/2009 18:01:10
Edited By JasonB on 04/08/2009 18:03:46
