However, a major source of bafflement is how some components, namely what are castings in real life, are made.
As a good example, which I think should answer all questions, I’m attempting to contact Norman to ask how he machined and finished the engine block. I can easily understand how cylinders, pistons, cranks etc are created, but how on Earth do you go about machining and finishing (and to a perfect state of polish, no less) the complex shapes of an engine block, starting with a solid bar of ali/ali alloy and conventional machine tools (none of that CNC nonsense, thank you)??
Can anyone give an insight, please?
P.S. not sure what happened to the thread title – it should read: ‘Norman Lawrence’s Napier Dagger’. No idea how one edits such things.
Edited By David Heskin on 30/09/2011 09:44:55
Edited By David Heskin on 30/09/2011 09:45:16
