So, what am I doing here you may well ask. No workshop but dad did take an interest and I learnt a bit from watching him. I've inherited some tools including a pillar drill, which has proved very useful.
18 years ago I signed up to buy a 5" gauge Britannia from Modelworks. Sold as a "bolt-together kit, its turned out to be more like an attempt to bolt together, fail, modify then bolt together.
In 2017, the frames were sent away to a professional to have the motion sorted out, I could not get a smooth running loco. After a year it came back working on air and with a bag of scrap metal – some original parts had to be remade, so a good move on my part!
After much work since then, it is now steaming and running on a rolling road. The blower seems to work with one injector, the smaller injector I fear suffers from the water feed passing too close to the firebox, the water is too hot for it to "pickup"??
Once the above is fixed I will fit the finishing touches, cab, running boards etc.
The advice I need now is regarding how to take the weight off the wheels for maintenance or to sort any derailment on the club track. Each 7mm diameter bar would slide into brackets, one under the smokebox and the other the footplate.They are 6mm thick and 100mm apart, the bar would be unsupported in the middle. The bar has to be 400mm long to clear the frames and give handlers enough to hold, so a lot of leverage at the lifting points, the loco, according to Modelworks, weighs 77Kg.
What metal should I use? Strong but not brittle would be my guess. I’ve tested silver steel but that just bent!
I’ve tried local engineering companies for help, they either refuse to give advice (“not qualified to do so&rdquo
or ignore my requests altogether.
Is there anyone that can give advice on what to use please?
