Just got in, made myself a cup of tea, sat down to flick through the newly arrived issue 4407 only to find more drawing errors before I’d even got half way through my mug
Great Western 5″
Dimension top right of upper frame drawing 4.531″
Add up the dimensions on the lower drawing and they come to 4.5″
Rider Ericsson
Base plate holes drilled on 33.6PCD
Cylinder holes drilled on 33.5PCD
Water Jacket 33.5mm diameter
Beam bearing plate which has a curve cut out so it fits the jacket, curve given as 38.5 RADIUS
Same error on pump pad, Water Discharge pad & crank bracket.
And where does one get 2.85mm silversteel and a reamer to suit?
Will finish my tea now before having a close look for more errors.
Can someone at ME at least look at the drawings rather than blindly copying or printing them.
Jason
Edited By JasonB on 29/06/2011 16:51:56
