No 20 machine oil
No 20 machine oil
Home Forums General Questions No 20 machine oil
Viewing 23 posts - 1 through 23 (of 23 total)
  • #404204
    AdrianR
      @adrianr18614
      In the manual for the mill i have just bought it specifies "No 20 machine oil" Could this be SAE 20W? would that be a suitable oil for a mill gearbox?
      Adrian
      AdrianR
        @adrianr18614
        #404209
        Tim Stevens
          @timstevens64731
          I think the answer will depend on the country where the instructions were written, Adrian. Rather like hat and shoe sizes, I'm afraid – so offer a bit more detail and someone (from that country, ideally) might be able to help.
          Cheers, Tim
          #404215
          AdrianR
            @adrianr18614
            It is Chinese, the original manufacturer/model is ZX-16 It was sold by Engineers Tool Room as the BMD-16
            #404217
              SAE 20W is unlikely to be suitable, it's the right viscosity only at Winter temperatures
              No 20 seems to be ISO68, with US sites recommending Mobil DTE Heavy/Medium
              Part of the fun owning an older machine is working out what the modern equivalent of long obsolete oils is! Usually one of the oils recommended for a similar machine will be suitable. However, when looking at alternatives bear in mind common modern oils are often engineered with additives and synthetics to suit today's requirements. These 'go faster' oils can have negative effects on older equipment, such as additives that attack copper in bearings, or low cold viscosities that only thicken up properly in a hot engine. Check the specification.
              Edit: It's a Chinese Mill!  Much less fussy.  I use Hydraulic Oil.
              Edited By SillyOldDuffer on 08/04/2019 18:11:57
              #404218
                Posted by AdrianR on 08/04/2019 17:27:21:
                Adrian
                Yes, SAE 20 is often specced for machinery gearboxes, it's quite thin so best for gears that run in a bath.
                  Well… that's three completely different answers to choose from…
                  AdrianR
                    @adrianr18614
                    Excellent ISO 68 SAE 20 is the same oil as the lathe needs.
                    I was thinking of Lodexol if I can find it in a smaller quantity or Liquimatic
                    Anyone know another?
                    #404239
                    Martin Connelly
                      @martinconnelly55370
                      And this is the lathe.
                      The mill is in the vehicle pulling the trailer.
                      Martin C
                      #404297
                      Brian G
                        @briang
                        I had been looking at Alex Oils for SAE 20/ISO 68 and noticed that there are two alternatives, Lumach 68 Lubricating Oil and Lubron ISO 68 Hydraulic Oil. Given that they are both the same price, would there be any advantage to the hydraulic oil?
                        #404303
                        Anonymous
                          I use a straight ISO68 hydraulic oil for my lathe headstock gears and the spindle, and powerfeed, gearboxes on the my horizontal mill. No need to EP oils, neither machine is particularly powerful, less than 5hp. I use an ISO68 slideway oil for general machine lubrication. A slideway oil has additives that make the oil slightly sticky, so it stays on the slideways.
                          #404845
                          AdrianR
                            @adrianr18614
                            I have been reading about the effects of sulphur used in the EP additives on yellow metal bearings. Are hydraulic oils free from sulphur and compatible with yellow metal bearings?
                            Adrian
                            #404848
                            Thor 🇳🇴
                              @thor
                              Posted by AdrianR on 13/04/2019 08:38:33:
                              Adrian
                              Hydraulic oils have many additives, usually also anti-wear additives (like zinc dialkyldithiophosphate), see here, or here. Sulphur based EP additives may attack yellow metal bearings. But I have never experienced any problem with hydraulic oil and yellow metal bearings.
                              Thor
                              #404863
                              AdrianR
                                @adrianr18614
                                Hmm, just been reading about zinc (ZDDP), it too can corrode yellow metals.
                                I did contact Warco about their headstock oil. They say it is suitable for the BH900 but wont tell me the ISO or SAE, so I am not too keen to put it in the mill. Plus it is quite expensive.
                                So these two, including delivery only £4 difference in cost; Lubron zinc free or Morris liquimatic which also comes in a nice old fashioned tin. I think the tin wins, order placed.
                                #404865
                                  …Are hydraulic oils free from sulphur and compatible with yellow metal bearings?
                                  Adrian
                                  It's dangerous to generalise. These days most oils contain additives of some sort. Usually a good thing, but sometimes incompatible with a particular machine. EP ( 'Extreme Pressure' ) oils often, but not always, contain a sulphur based additive that attacks copper alloys. The same additive may be in oils other than EP types.
                                  In case of doubt, read the data sheet. This Morris example includes the phrase, 'Compatible with all bronze, silver and steel system parts'.
                                  My rules of thumb in the workshop for lubricating in the absence of proper instructions:
                                  1. Never use grease when oil is specified or vice versa
                                  2. Any oil is better than no oil.
                                  3. Avoid modern motor oils; these are designed for service in a hot car engine and are highly engineered for that purpose. (Old-fashioned straight motor oils are more general purpose but are getting hard to find.)
                                  4. Getting the viscosity about right is often 'good enough'
                                  5. Hydraulic oils are generally useful for everything. (EP types are usually unnecessary unless the specification calls for it.)
                                  Edited By SillyOldDuffer on 13/04/2019 10:17:27
                                  #404867
                                  AdrianR
                                    @adrianr18614
                                    Hi Dave,
                                    The Morris oil in your example is the one I just ordered. So all good.
                                    Adrian
                                    #404872
                                    Robert Atkinson 2
                                      @robertatkinson2
                                      +1 for Morris lubricants. They even make steam oils.
                                      #404902
                                        Here's an example of a substitution I have found works very well… using sewing machine oil instead of 'lemon oil' for guitar fingerboards. 'Lemon oil'* for this purpose is just highly refined thin mineral oil with a scent added, sewing machine oil is just highly refined thin mineral oil.
                                        *Not to be confused with pure lemon oil which is irritant to the skin.
                                        #404909
                                        Ed Duffner
                                          @edduffner79357
                                          Does the ZX-16 (BMD-16) have an oil-fillled gearbox? It appears to be a bench top mill similar to others which have grease lubricated gears, like my Warco WM-16.
                                          Cheers,
                                          Ed.
                                          #404938
                                          AdrianR
                                            @adrianr18614
                                            Ed,
                                            Yeup, defiantly was oil filled. After removing the motor, I lay the head down and forgot about the oil. I now have a nice puddle on the new workshop floor.
                                            FYI this is it.
                                            Adrian.
                                            Edited By AdrianR on 13/04/2019 19:58:46
                                            #404948
                                            Bazyle
                                              @bazyle
                                              Hydraulic oil is just water that doesn't rust things. The clue is in the name. It is expected to be pumped around cold things so is thin and 'cos it is oil based it sort of lubricates.
                                              Oil for car engines is thicker because it is doesn't get pumped around much and needs to do some serious lubricating of those slidey things called pistons. This also works for the gears in the car gearbox. But it has al sorts of additives to cope with the heat and yucky stuff that the suck squeeze bang out process contaminates it with. They are thicker when cold but at their normally hot operating condition are a lot thinner.
                                              A midway point is automatic gearboxes. They have gears that want lubricating, don't get too hot so need to be thinner to start with, no yucky byproducts to deal with, and have pumps that run the actuators so that also needs them to be thinner.
                                              Which of the above sounds closest to your application?
                                              #404970
                                              duncan webster 1
                                                @duncanwebster1
                                                Posted by Bazyle on 13/04/2019 21:12:28:
                                                That's not quite right, hydraulic oil comes in various grades from ISO 22 (thin) to ISO 100 (thick). I use 68 in the headstock of my lathe, and I believe I'm supposed to use 100 in the vertical head of the milling machine. I actually use some thickish stuff I was given, so you will see I don't think the exact spec matters all that much. I wouldn't advise using slideway oil in a gearbox (as advised by Myford), I've had problems with it separating out
                                                #405056
                                                Jon
                                                  @jon
                                                  Correct Duncan hydraulic oil comes in various viscosities and is used in cars namely power steering. Most modern petrol cars run 5W/30W equivalent to ISO 32 when cold.
                                                  Hydraulic goes well in to the 100W think 150W where older car axles used EP80 or 90.
                                                  Slides and beds much prefer Hydraulic 32, you can feel the drag with Hydraulic 68.
                                                  Gearboxes hydraulic 68 and flows more like a 20W when warm.
                                                  Best bit is its the cheapest of most oils around £17 a gallon delivered from Smith and Allen, must get some more 32.
                                                  You can even get Anti Wear Hydraulic called AWD32 or 68 etc.
