Nibbler Article
Nibbler Article
Home Forums Model Engineers’ Workshop. Nibbler Article
  • #151748
    John Burridge
      @johnburridge26484
      I have read the latest article on the nibbler which I think is very good, Only one thing seem wrong, The mention of the 3/8" X 20TPI thread it should normally be either 3/8" X 24TPI or on bigger drills 1/2 X 20 TPI
      3/8" X 20 Is BSF and not the standard 3/8 and 1/2 UNF threads
      John B
      Typo
      Edited By John Stevenson on 07/05/2014 19:17:21
      John Burridge
        @johnburridge26484
        electric drill chuck thread
        #151750
        Michael Cox 1
          @michaelcox1
          Hi John,
          I cannot check at the moment but I think it should read 1/2" x 20 TPI for the drill I used. Thanks for pointing out the mistake.
          Kind regards
          #151800
            I've just checked a couple of my chucks, and yes it is 3/8" x 24 and 1/2" x 20. I've made enough adaptors for tehse things, I should have spotted it.
            A very ingenious use of the nibbler, having cut a few inches off the end of a stainless steel sink with a hand cutter (the type that make s a coil about 1/8" wide) so it would fit in a camper, I can see many benefits.
