Newton Tesla CL series
Home Forums General Questions Newton Tesla CL series
  • #44990
    Jim K
      @jimk
      I am sure there are owners here who have fitted this conversion to an under drive lathe,
      I am thinking of adding this modification to my lathe or simlar so please recommend other options. My question is when fitting the conversion do you fit the motor in the original position and use the same pulley drive system, or do you rip it all out and modify to have a more direct drive.
      JimK
      Edited By Jim K on 13/11/2009 03:17:41
      Jim K
        @jimk
        Fitting to a Boxford Lathe
        #45035
        John, Newton Tesla
          @johnnewtontesla
          Hi there.
          The standard motor supplied with the Newton Tesla CL750 lathe speed control systems is a direct fitting replacement for most Boxford underdrive machines (same shaft diameter of 5/8″, same centre height and same foot fixing centres). All except the Boxford VSL machines which had the same frame size of motor –  but fitted with an electro-mechanical brake on the non-drive end.
          You can keep the existing pulley system.
          On our elderly Myford ML7 lathe – we tend to leave the belt arrangement in a mid-speed range and then let the speed control do the rest.
          Hope this helps.
          Regards,  JohnJN
          #46495
          John Wood1
            @johnwood1
            Hi,
            I have recently fitted the CL750 controller to my Warco WMT300 with great success. As John does with his Myford I leave the lathe’s belt on a medium range and simply use the Teslar speed control – it’s magic!
            Regards   John
            #733704
            Chris Finn
              @chrisfinn79763
              Hi.
              Can anyone give me the size of the CL750 box. I can’t find any details on there pages that will give me that information.
              Thanks, Chris
              #733783
              Nick Hughes
                @nickhughes97026
                280mm Tall (Over mounting flanges) x 215mm Wide x 95mm Deep (Mounting face of flange to front face)
                Nick.
                #733785
                Chris Finn
                  @chrisfinn79763
                  Hi Nick
                  Many thanks its as i thought quite large but at lesst now i can see if i can make it fit.
                  Much appeciated.
                  Chris.
