Posted by DC31k on 16/02/2023 15:58:58:
Posted by Clive Foster on 16/02/2023 13:13:51:
I'd go for 2 hp (or more) rather than matching the 1 hp motor specification.
The motor in his photo is badged 1/2 hp in one speed and 1/4 hp in the other.
Given the passage of considerable time and the ongoing march of technology, how much weight should we assign to your experience of 15-20 years ago?
Your observations on Holbrook and the like could be misleading insofar as we need to consider the amount of inertia the motor is being asked to overcome and the rolling resistance of the drivetrain. It is the difference between an American muscle car and a Lotus 7.
In addition, the VFD will offer a soft start (ramp up) capability, so the initial current demand will be considerably less.
DC31k
Sorry missed your post earlier.
The march of time and technological advancement makes very little difference here as we are dealing with fundamental motor physics.
The issue is how big are the storage capacitors and how much energy is available to run the motor up. Even with soft start there is no getting around the fact that a motor is near as dammit a dead short when turned on. It needs a certain current flow and voltage to get it moving. If too much energy is sucked out of the capacitors too quickly the applied voltage falls too low before the moron gets moving and it cannot start. Just sits there and buzzes. Basically acting as a seriously weird transformer.
My big tome on motors has whole chapters devoted to calculating the immediate inrush current and design methods to control it so that a motor will reliably start under load without upsetting the local supply. Very important if running off a generator. Star-Delta switching and avoiding multi-speed motors being the easy beginning before the maths goes to eye-watering, brain leaking out of your ears level. 1970's book so it assumes algebra, slide rule and mechanical calculator level calculation.
The VFD Rich has is clearly undersize in the storage capacitor department when it comes to meeting the inrush current on the high speed setting. Only having 380 volts doesn't help as, obviously, the lower voltage reduces the energy the capacitors can store. Which may well be enough to make the difference between not quite and just enough.
Large capacitors are expensive.
As ever with economy range you have to expect usually good enough engineering and specifications. Which is excellent until it isn't.
Buying a higher power unit basically gets you bigger capacitors and more oomph to get things going.
It's annoying that, apparently, no-one makes professional level versions of these step up VFD boxes where there are no hidden performance issues. You'd have thought there would be a big market in America as an alternative to expensive Phase Perfect boxes and the like.
In the previously mentioned Holbrook application the motor only drives the gearbox on start up so the load was not be great. But the inrush current is still very, very high. With my Smart and Brown the modified VFD just ran out of volts at high speed. The capacitors were clearly adequately sized as the machine started OK. In standard trim running 440 volts that VFD would have had no problems.
