Newcomen Atmospheric Engine
Home Forums Beginners questions Newcomen Atmospheric Engine
Viewing 25 posts - 1 through 25 (of 39 total)
  • #613021
    Michael Moore
      @michaelmoore38916
      Hi
      Just wondering about the process for the cool water injection into the cylinder to create the vacuum. Do we know how was this was done on an early 18th-century Newcomen engine, and how it's done on models of today.
      I thought perhaps with gravity by housing water higher than cylinder, but I'm not sure if this would work as I'm an absolute beginner to models, engineering, physics, etc.
      Ta,
      Michael Moore
        @michaelmoore38916
        #613029
          This shows a simple header tank, Michael : **LINK**
          https://www.nms.ac.uk/explore-our-collections/stories/science-and-technology/newcomen-engine/
          Sorry, I have no experience of scaled-down model versions.
          Dave Wootton
            @davewootton
            There's a full size replica at the Black Country Living Museum in Dudley, fascinating to watch in steam and it is run when the museum is open. The staff are very friendly and knowledgeable. If you can't get there there will be info on their website. There used to be a Science museum book called James Watt and the separate condenser that had a lot on these early engines.
            Also David Hulse's website has details of his wonderful models of early engines, can lose yourself there for a while!
            Fantastic place worth a visit if you can.
            Edited By Dave Wootton on 11/09/2022 14:38:56
            Edited By Dave Wootton on 11/09/2022 14:43:21
            #613039
              Depends I think on the date of the engine. This picture is of a Smeaton improved engine, he eventually tripled the efficiency of Newcomen's original by optimising the relationship between piston diameter and length of stroke, the number of strokes per minute, and the size of the boiler.
              In this example the boiler isn't immediately below the cylinder, which I think means Smeaton was able to do better than the original pot boiler.
              However, the engine:
              • Lifts cold-water into high-level tank O with a chain pump dropped down Pipe N. The pipe goes down a well. The pump chain is driven by a separate beam linked to the main beam (I)
              • Cold water flows from tank O along Pipe P. A proportion of it is diverted to the top of the cylinder by pipe f. Pipe f feeds water to the top of the piston, the amount being set by Tap r. When the piston rises, any surplus water on top is drained into the Hot Tank S. The purpose of this top feed is a little controversial: some say the water just improves the piston seal, which was very poor. Others say the vacuum stroke also pulls cold water in at the cylinder top and significantly increases the power of the engine.
              • The other end of Pipe P feeds cold water into the bottom of the cylinder, via another tap r, which is turned on and off by lever g, is driven by pegs on rod Q. In the original engine, water just flowed from a single orifice into the bottom of the cylinder. In this drawing, dotted lines show pipes set up to spray water into the cylinder from several places. Several sprays condense the steam quicker than a single pipe for more power, better efficiency.
              • After the stroke, hot water is emptied into tank S, and used to top up the boiler.
              Modelling these engines is said to be difficult because they're intrinsically very inefficient plus their physics don't scale down well. The very best a vacuum can achieve is only 14psi which can't put much force onto a model sized piston driving quite a lot of mechanism. And on practice the vacuum will be much less than 14psi because the surface area of the small cylinder and piston is large compared with their volume. Thus heat is lost rapidly even before any cold water is sprayed in, and there may not be enough vacuum at the right time to rock the beam. Bigger is definitely better when it comes to atmospheric engines.
              Howard Lewis
                @howardlewis46836
                You can see how James Watt improved efficiency by moving the condensation process out of the cylinder to reduce heat loss within the cylinder.
                With such a small pressure difference the piston and cylinder need to be large to produce enough power merely to overcome friction and accomodate the heat lost to the incoming steam caused by the in cylinder condensing.
                Friction will be proportional to the cylinder diameter (Circumference ) while area (Force available ) will increase as the square; so bigger is better.
                #613067
                Michael Moore
                  @michaelmoore38916
                  Thanks all. I'll attempt to process these posts and links tonight. Everything has to be read and watched scores of times before it sinks in with me. Ta.
                  #613109
                  Andy Carlson
                    @andycarlson18141
                    Coincidentally I was looking at the example in Dartmouth a few days ago.
                    IIRC Watt is supposed to have been working with a 'model' of a Newcomen engine when he made his improvements… which begs the question… how big was the model?
                    #613113
                    John Olsen
                      @johnolsen79199
                      There is a working replica of a Newcomen engine in Whangaparaoa near Auckland NZ. It was built by the Auckland Steam Engine Society. When I say replica, there are no scale working drawings of any of the original engines, or any original engines to take drawings from, so the most we can say is that it is like the originals and works on the same principle. It stands about twenty feet high and the pumped water is used to turn a small waterwheel, maybe 6 feet or so in diameter.
                      There was a kitset for a model one being sold a few years back, one of the local guys here in NZ bought one and it did work to at least some degree, with some difficulty at times. It was maybe 18 inches or so tall.
                        Thanks for the reference, John yes
                        There is an interesting paper about that one : **LINK**
                        https://www.tandfonline.com/doi/full/10.1080/17581206.2018.1463720?scroll=top&needAccess=true
                        Fortunately for me … I have ‘Institutional Access’
                        Unfortunately for everyone else … I am not permitted to share the download
                        Sorry
                        One short but important quote is permissible under ‘Fair Use’
                        This project has proven that small Newcomen engines can be made to work successfully and suggest that more ongoing research into the design of the valve gear of the early engines is required in the future.
                        keywords  New Zealand built, 21st century, working (operating), Newcomen engine
                        DOI 10.1080/17581206.2018.1463720
                        INT. J. FOR THE HISTORY OF ENG. & TECH., Vol. 88 No. 1, 2018, 135–163
                        Edited By Michael Gilligan on 11/09/2022 23:25:28
                        #613117
                          Both versions of this rather splendid image are freely downloadable, at quite a respectable resolution:
                          https://collection.sciencemuseumgroup.org.uk/objects/co50905/print-of-henry-beightons-engraving-of-a-newcomen-engine-print
                          Edited By Michael Gilligan on 12/09/2022 00:09:52
                          #613121
                          John Olsen
                            @johnolsen79199
                            Hi Again, I've created an album with some of my pictures of the construction of the Auckland Newcomen Engine.
                            Hopefully this link will get you to the album, rather than overloading this thread with links to all the individual pictures.
                            Auckland Newcomen engine album
                            As you will see if you look at the picture of the top of the beam I was involved in the project sufficiently to get my name carved into the beam. In particular I remember cleaning a lot of those bricks. I think that might be me at the top of the engine when the half barrel was being hoisted in place.
                            I've included one shot which shows part of a model Newcomen engine, not the best shot since it was really of the people, but it will give some idea of what the model is like. The flywheel belongs to another engine behind it.
                            regards
                            John Olsen
                              @johnolsen79199
                              Getting back to the original question, I think that half barrel being hosted up in one of the pictures contains the water that is used for the condensation. It sits on top of the frame, although on an original engine it would probably have been somewhere in the engine house. It doesn't need a lot of head, since the pressure in the cylinder is never high.
                              If anyone wants to use any of the images, I have no objection to any non commercial use like club newsletters or personal study.
                                Posted by John Olsen on 12/09/2022 06:25:15:
                                Hopefully this link will get you to the album […]
                                Many thanks for sharing the pictures, John
                                … and yes, the link works fine.
                                P.S. __ although Newcomen’s engine is hopelessly inefficient in technical terms, I have always considered it one of the finest examples of ‘Man the Tool-Maker’ …
                                Edited By Michael Gilligan on 12/09/2022 07:24:06
                                #613131
                                John Haine
                                  @johnhaine32865
                                  Our school history teacher told us a tale of a lad at a mine employed to turn the water and steam on and off. Being perennially sleepy he rigged up an arrangement of levers and string to do it automatically. Foreman found him asleep on the job and he was promptly sacked.
                                  #613136
                                    Posted by John Haine on 12/09/2022 07:46:15:
                                    … Foreman found him asleep on the job and he was promptly sacked.
                                    Thus demonstrating the Peter Principle ?
                                    P.S. __ the character at (c) in the engraving that I linked appears to be dozing peacefully
                                    Edited By Michael Gilligan on 12/09/2022 08:10:10
                                    #613159
                                      The boy Potter may be a myth, like Newton understanding gravity after being hit on the head by an apple and Watt being inspired to invent the steam engine by his mum's kettle lid lifting when it boiled.
                                      It's possible the "boy" in question is a misunderstanding. Another explanation is that early automatic atmospheric engines featured a Buoy Valve, which someone assumed meant a child was involved. Buoy valves aren't unlikely in pumping engines – Cornish Engines all had Cataract valves. (In British English buoy is pronounced boy, rather than Boo-ee in English as she is spoke in the USA! )
                                      It's true the valves on Newcomen's first engines were operated manually and so it's possible the job was done by a real boy with strong practical skills and engineering insight. But if I'd built an expensive state of the art pumping engine to keep a costly coal mine dry enough to work in, I'm not sure I'd trust an unsupervised boy to drive it! More likely various clever experienced men tried a number of different methods, and settled on what seemed the best. At that point the small-c conservatives who infest British engineering seem to have taken over: a century later the beam and valve-gear on Watt's early engines is very Newcomen.
                                      We will never know whether or not the boy really existed unless something turns up in a musty archive.
                                      John Olsen
                                        @johnolsen79199
                                        I suspect that the boy was a myth.
                                        With the Auckland engine the valves are worked manually until things are going well, then they work themselves. That sort of operation was actually still used on American walking beam steamers until the last years of their use, into the last century. The Cruquius engine in the Netherlands has something similar.
                                        michael potts
                                          @michaelpotts88182
                                          You need to get hold of a copy of 'The Steam Engine of Thomas Newcomen', by Rolt and Allen. Get the Landmark edition of 1997 if possible, it has a better bibliography. This book does mention a wide range of information about this engine.
                                          Gravity was used to give a pressure to the injection water. It was simple and effective. When John Smeaton started to look at the design of the engine around 1770, he said that the injection water system should be as high as possible in the engine house. He also specified that the injection water nozzle should be square. This broke the jet up to provide a better spray. To see how this works, look at the internet site ' physicsgirl smoke rings ', and see the effect of blowing a square smoke ring. Water, being denser than air would be slightly different, it would tend to fly outwards.
                                          Getting water up into the injection tank was an interesting problem. The Thomas Barney 1719 engraving of the Dudley Castle engine shows a small pump connected to the beam by a heavy connecting rod to pressurise the water sufficiently for it to rise to a level where it could flow into the injection cistern. The jack head pump came a little later ; it was connected on the main pump end of the beam by a light chain. As the main pump was lifted, the jack head piston was also lifted, forcing water up a pipe to the cistern. The John Smeaton engine drawing shows a more complicated arrangement using an auxiliary beam to operate a lift pump by a chain connection.
                                          Model Newcomen engines have different problems, you would probably need a small motor driven pump to supply injection water at three or four psig. The main pump on such an engine works best using a jack head pump with an adjustable valve to control the flow of water from the pump. A friend of mine had a model engine, built by a toolmaker from his scrap box. I first saw it about 1998 or 99 at a Heritage weekend at Elsecar. I walked into a room with this model working away in a corner, started talking to the operator, and over twenty years later we are still talking. His engine was driven by steam from a pressure cooker, ran very effectively, and provided information about these engines that can be found nowhere else. This engine has now worn out, he has another that he built based on the Dartmouth engine. The single lever valve gear has caused problems, so is probably unsuitable for a model. He thinks that model Newcomen engines can work very well, but do need care, starting with the fit of the piston in the cylinder.
                                          The model Newcomen engine that James Watt worked on still exists. It is in the Hunter Museum in Glasgow, an example of a clock maker's or instrument maker's skill. There is a similar model in Kings college at the University of London.
                                          Jim Andrews wrote a paper about the differences between the Newcomen and Watt engines, and gave talks about it. The paper does not appear to have been published.
                                          Over the last three hundred years a huge amount has been written about the Newcomen engine. The Newcomen Society has published nearly ninety papers about it. Over thirty years ago I began to read about it, and when I was deemed too expensive to employ in 1992, I began work on a patented version dating from 1790, the Heslop engine. Twenty years later I had just about worked out who did what and when and read a paper to the Midlands branch of the Newcomen Society when a row broke out about the site of the 1712 Newcomen engine. So, along with some other people I started to look at the evidence. I did come to a conclusion about it that fitted with some of the contemporary writings ( Well, about thirty years after. ) I have continued to collect information about this engine and others. We still have large gaps in our knowledge and understanding of these machines. People talk about the lack of efficiency of these machines, but at the time there was nothing else that could get water out of mines, apart from water wheels and windmills. The problems that they had are still with us in renewable generation of power.
                                          I think that is all for now. The history of this engine sprawls everywhere, and fresh items keep coming to light. In 2020 I found nine separate items from auction sales to paintings, drawings and one article about a well known engine that I did not know existed. Two items allowed me to estimate the size of engines that we know existed, but knew nothing about. If you think that we do not know a lot about English engines, then the Scottish engines hardly exist at all, and European engines are very difficult to find anything about apart from the fact that they existed in some cases.
                                          If anyone has any further questions I would be happy to discuss them.
                                          Regards. Mike Potts.
                                          #613176
                                          michael potts
                                            @michaelpotts88182
                                            The valve gear ? My colleague thinks that Thomas Newcomen ever rented a commercial engine with hand operated valves ; the dangers of a disaster were simply too high. We know the Dudley Castle engine had automatic valve gear, because when it was started up for the first tie, ' It made several strokes very quick '. This could not have happened with manual gear.
                                            The story about the boy running the first prototype engine in Cornwall about 1703 could well be true. No one else had the opportunity to actually see what was happening. It is noticeable that the steam valve operation is simple, but the injection water valve operation is much more complicated,using the ' Potter cord '. .
                                            Sorry for these omissions.
                                            #613182
                                            Michael Moore
                                              @michaelmoore38916
                                              Thanks to all for the posts, picture albums, and links, they're helping me get a better understanding. I do plan to visit the Newcomen engine in the Black Country at some point as I'm fairly close in North Brum.
                                              I've found what looks to be an interesting video lecture (youtube) by Mike Potts on the history of the Newcomen engine. I fell asleep watching it last night, but I plan on finishing tonight.
                                              #613184
                                              Michael Moore
                                                @michaelmoore38916
                                                Funnily enough I've been looking at a copy of 'The Steam Engine of Thomas Newcomen' by Rolt and Allen on ebay. I'll check to see if it's the 97 edition. It has a red and green cover and priced around £20-£30 if I recall.
                                                Edited By Michael Moore on 12/09/2022 13:21:30
                                                Edited By Michael Moore on 12/09/2022 13:26:56
                                                #613188
                                                Michael Moore
                                                  @michaelmoore38916
                                                  Ah you're here, Mike. That's looks a great channel, I plan on watching the William Pitt Winding engine lecture after I finish your other one. Thanks, Mike.
                                                  #613193
                                                  Andy Carlson
                                                    @andycarlson18141
                                                    Somewhat off the OP's question but… are any specifics known about the use of Newcomen engines at Polgooth/Mulvra in Cornwall? I have heard mention that one or more was thoight to have been used there. The history of Polgooth is one of my other occasional interests.
                                                    #613200
                                                    Michael Moore
                                                      @michaelmoore38916
                                                      According to Mike Potts there's no explicit documentary evidence pertaining to the two Cornwall engines, only circumstantial evidence.
                                                      Edit: incorrect surname
                                                      Edited By Michael Moore on 12/09/2022 14:07:42
