Newbie with no prior skills on lathe
Home Forums Introduce Yourself – New members start here! Newbie with no prior skills on lathe
  • #40943
    Jodey Powell
      @jodeypowell60570
      Drummond type m lathe
      Jodey Powell
        @jodeypowell60570
        Hi all I have been captivated with the drummond type m lathe that i purchased a few weeks ago i have stripped it down to every last nut and bolt fully cleaned taken back to bare metal repainted and re assembled it in a weekend I just hope I did it proud.it a marvellous piece of kit but now need help to get on with the real task of learning how to use it properly any help would be much appreciated.
        #506675
        Thor 🇳🇴
          @thor
          Hi Jodey,
          Welcome to the forum and congratulations with your "new" lathe. If you are a beginner with metal turning lathes you should try and find out if there are any model engineering clubs near you.
          I assume you have already visited the lathes.co.uk site, they have a lot of info on Drummond lathes. There are several books that I found useful when I started the hobby many decades ago, may be your local library can get them for you, here are a few examples:
          The Amateurs Lathe by L.H. Sparey
          Lathework. A complete Course by H.Hall (Workshop Practice series #34)
          Screwcutting in the Lathe by Martin Cleeve (Workshop Practice series #3)
          You should also be able to download some old books from the web:
          ***Link***
          ***Link***
          Thor
          #506680
          Ady1
            @ady1
            Get the sparey book
            Start by whittling down bits of scrap to get a feel for things, take your time and take care, flesh is easily removed by revolving chucks etc
            edit: A decent M is one of the best hobby lathes ever made
            GL
            Edited By Ady1 on 11/11/2020 09:18:45
            #506689
            Chris Evans 6
              @chrisevans6
              Welcome to the forum, put an approximate location on the board There maybe someone local who can advise you.
              #506770
              Lee Rogers
                @leerogers95060
                Welcome . A good set of ready to go HSS tools is your starting point , not too many , a set of 4 of 6 will get you started and beyond. If your learning you'll just find a world of pain with insert tools . Not that the Drummond cant handle them if used appropriatly just that it's task up from the basics. The lathes.co.uk site also has some general basic how to pages , well worth a read. Have a look at the Drummond Myford group on FB friendly bunch and a wealth of Drummond knowledge.
                #506789
                Brian H
                  @brianh50089
                  Hello Jodey and welcome.
                  As well as the Lathes site it might also be worth looking at ;
                  #506793
                  colin hawes
                    @colinhawes85982
                    Hi Jodey, always making sure the cutting tools are very sharp will give you a good start with your turning. Colin
                    #506805
                    Howard Lewis
                      @howardlewis46836
                      Yes, get "The Amateurs Lathe" by LH Sparey, It will give you advice on setting up the lathe and grinding tools.
                      Although a lot of what he shows refers to the Myford ML7, the book contains the basics, which are applicable to any lathe.
                      Another book that you will ,find useful, as a reference for all manner of things is Tubal Cain's "Model Engineer's ,Handbook"
                      Lathes UK, website is a huge mine of information.
                      Joining a local Model Engineering Society will bring you into contact with other enthusiasts, who will help with advice, and probably demonstrations of techniques and equipment.
                      The Drummond was never designed for Carbide tools, so stick with using High Speed Steel, would be my advice.
                      As you become more experienced, you will, need to add, if you do not already have,
                      a Bench Grinder
                      Measuring equipment (Callieper, Vernier, Dial or Digital. )
                      Vernier, you will need to learn to read a vernier scale (They are used on a lot of measuring instruments )
                      A Dial Calliper will show a reading, directly on a dial with reference to the scale on the main body.
                      Digital, has the advantage of the reading being immediately easily visible, and can be change by the press of a button from Imperial to Metric.The disadvantage is that the battery may well go flat just when you need it most! Keep a spare!
                      Then you will find a need for Dial Test Indicators, (Plunger types often graduated in 0.001" ) and Finger type (The generic type is Verdict ) usually graduated in 0.0005"
                      These will need to be mounted on a base, usually, nowadays, a Magnetic type. My preference is for the type without an adjuster on one of the stems, to maximise rigidity.
                      You will soon find a need for a Drill Chuck to go into the Tailstock
                      It may well be an advantage, if you have not already got them, Centres to fit into the Headstock and Tailstock.
                      As you will already know, the Drummond is an old British machine, so the threads and dials will be Imperial,
                      ( BSW or BSF ). In the right hands, it is capable of turning out good work.
                      Having ground tools, it is important that they are mounted so that the cutting edge is on the centre line of the Mandrel. In this way, when you face the end of a bar, there will, be no "pip" in the middle. It is worth making a Centre Height Gauge. This can be an early learning exercise, whilst getting used to the lathe and to metal turning.
                      HTH
                      Welcome and Enjoy.
                      #506827
                      David George 1
                        @davidgeorge1
                        Hi Jodey welcome to the forum. I have an M Type as well and have done many upgrades and mods like tumbler reverse, drip feed lubrication for spindle, and change toolpost to quick change. I have a copy of the handbook and if you want a copy drop me a message with an email address or just ask if you need any further information.
                        David
                        #506835
                        old Al
                          @oldal
                          Books are a good second choice and the books mentioned are very good and easily found. A few minuits with someone that knows lathe work could take months to learn from a book
                          #507007
                          Howard Lewis
                            @howardlewis46836
                            There you are; actual users, (There are several on the Forum, scattered across the world ) who are really familiar with the machine and are ready to advise and help.
                            Even better if you can find someone near to give you some basic instruction, face to face, as soon as things start to approach what used to be normal.
                            Finding, and joining a local Model Engineering Society will be a good move.
                            If you say where you are located, possibly someone nearby may be willing to help you. (Even if it is not on a Drummond, the basics are the same, and can be used on almost any lathe once you have learned the
                            techniques ).
                            Once you can grind a tool and set it up, you can learn how to provide a steady hand feed for turning, and facing. You have a load of new words , terms, and techniques to learn. The more that you do, the more confident and proficient you will become.
                            But you are unlikely to be screwcutting or making any tiny engines for model aircraft for a while.
                            Walking comes a long time before running. It took me a little time to realise that putting on a 0.010" cut reduced diameter by 0.020"!
                            HTH
                            Edited By Howard Lewis on 12/11/2020 15:09:35
                            #507016
                            Speedy Builder5
                              @speedybuilder5
                              As you practice machining metal, they are all different and sometimes scrap metal turns out to be awful stuff that should have been thrown away. Don't give up, ask a question "Why did I get an awful finish".
                              Enjoy
                              Bob
                              #507040
                              Howard Lewis
                                @howardlewis46836
                                Yes, I should have warned against rebar. Don't know what it contains, but it is not nice to machine. AVOID!
                                Start learning on Free Cutting Mild Steel.
                                Odd offcuts from a machine shop can be anything. Some will cut beautifully, the next bit may defeat every attempt to get a decent finish, even with a recently ground tool set exactly on the centreline.
                                Howard.
