As an extravagance, I bought a secondhand mini lathe.
In the process of making a Centre Height Gauge for it I checked the run out of the 3 jaw chuck. It was quite small, of the order of 0.005" (0.017 mm )
Imagine my surprise when I found that one of the jaws carried a different serial number from the other two!
Since i am the second owner of the lathe, I do not believe that the seller would have changed the jaws, so conclude that the machine left the factory like that!
Clamp a piece of Silver Steel in the chuck, and check the run out. If it small, like mine, I would not worry.
If it is excessive, then my suggestion would be to make up a ring and then grind the jaws.
If grinding in this way is impossible, a rough and ready way would be to clamp all three jaws in such a way that outer faces are all against a good flat surface, and then to grind the highest jaw down to match the others, CAREFULLY. This assumes that the OD of the jaws are all the same!
Might be worth checking to see if the outer sides of the jaws align exactly, when checkingb the run out of the Silver Steel.
Are there any outside Jaws with the chuck? If so, have they all the same serial numbers?
Edited By Howard Lewis on 07/10/2019 19:15:15
